Spokes
I appreciate the input!
7-12-24 Update. As previously assumed that the engine may have been rebuilt incorrectly, I have to back pedal. I decided to tear down the cylinder head today and found this.  I also found the oil pump body cracked. So, the total damage was cracked cylinder base, broken rod with the rod bearing gone, bent valve (exhaust) One piston destroyed. Upper case broken behind the starter. The cause of the engine failure? Likely, someone just revved the engine as high as she could rev until the engine overheated and exploded. Ah! OK. I have not looked closely at the top end, referring to the head/OHV/tachometer assembly. I can tell you that one cylinder is broken at the bottom and one piston has damage. I will get some pictures in for reference, my guess and only conjecture and it may sound wild, but it appears the engine may have been rebuilt and for sone crazy reason one piston rod was not attached to the piston. Kind of slapped together. So, when whoever hit the starter button the free rod tore into the piston bottom, breaking off the lower cylinder and sending the pieces through the upper crankcase. I get some shots uploaded in a few days. The serial number on these engines happens to be on the upper crankcase. The upper crankcase is damaged. Pictures soon!
That bent valve would make a nice trophy part for a Memorable Mongo Maneuver award.7-12-24 Update. As previously assumed that the engine may have been rebuilt incorrectly, I have to back pedal. I decided to tear down the cylinder head today and found this.  I also found the oil pump body cracked. So, the total damage was cracked cylinder base, broken rod with the rod bearing gone, bent valve (exhaust) One piston destroyed. Upper case broken behind the starter. The cause of the engine failure? Likely, someone just revved the engine as high as she could rev until the engine overheated and exploded. View attachment 34587
Did not know you could open these and service them. Thanks for sharing !!!I dearly miss is the simplicity of mechanical/electrical aspects of yesteryear. Which is another reason why I take on the old junkyard Honda Dreams. In this case, the starter solenoid. I use a 6-volt lantern battery and a continuity light to check electrical connections. Today, I checked the starter solenoid. No response. Dead. But no! The starter solenoid sat idle for nearly 60yrs in the frame. The starter solenoid top and bottom is removeable. A little 10wt oil (aka 3 in 1) on the plunger shaft inside and on the bottom of the plunger outside freed up the electro mechanism. Another piece of the puzzle put away until final reassembly. View attachment 34594View attachment 34595View attachment 34596
I wanted to follow up with a few pictures of the engine I bought for my 62 project and the costs for example. I found a super low mileage 1963 CA95 complete engine (370 miles on the odometer of the donor bike) in Owatonna Minnesota, 762 miles away from Lexington, KY. Price was $175. I sent a 60 qt Coleman cooler to the seller $ 67.00. FedEx shipping $148.00 (not bad for transporting 100#, 780 miles) So, $390 delivered. I went for this option based on the outrageous asking prices for pieces parts on eBay. Below are a few shots of the package.Always pleased to share tips!
Another tip I wish to share is shipping small engines the size of 150cc or less and greasy engine parts. Coleman or similar coolers. The cooler will prevent leakage and the lid can be secured with heavy tape and/or deck screws & washers. More expensive than cartons & bags, but a lot cleaner with less chance of leaks!
Oohh, I was hoping for grass fed beef steaks in that cooler …..filets, New York strips…… I guess a vintage twin is second best,!!I wanted to follow up with a few pictures of the engine I bought for my 62 project and the costs for example. I found a super low mileage 1963 CA95 complete engine (370 miles on the odometer of the donor bike) in Owatonna Minnesota, 762 miles away from Lexington, KY. Price was $175. I sent a 60 qt Coleman cooler to the seller $ 67.00. FedEx shipping $148.00 (not bad for transporting 100#, 780 miles) So, $390 delivered. I went for this option based on the outrageous asking prices for pieces parts on eBay. Below are a few shots of the package.View attachment 34656View attachment 34657View attachment 34658View attachment 34659
That's one of the funniest replies I've seen this year... and I could go for a grass-fed filet myself!Oohh, I was hoping for grass fed beef steaks in that cooler …..filets, New York strips…… I guess a vintage twin is second best,!!![]()
Actually, I did send the cooler via Amazon. Then I went "ship" shopping. FedEx provided best pricing and shipping time. UShip came in better than twice the price with slow boat delivery times. I will report out cooler and motor condition when the package arrives. Afterward I plan to inspect clutch side case. If no sign of metallic chips I will clean up the clutch plates and reassemble. If all goes well, I'll install the engine and fire it up late next month!Sounds like a great motor. Worth the extra for the cooler added protection. I've had shipping damage on the last two motors I bought on ebay from reputable salvage sellers.
I guess, you could have a cooler drop shipped to the seller from amazon, saving some extra cooler shipping.
Well, I can send any drippings from the cooler.....LOLThat's one of the funniest replies I've seen this year... and I could go for a grass-fed filet myself!
Yes. Roughly when installed and welded. I used a tapered reamer to reshape both the new metal and old metal. Then after final mud and finish before color.Do I understand correctly that your patch roughly matches the shape of the complicated hole in the original fender? The final result looks very good!
Thanks for the explanation!Yes. Roughly when installed and welded. I used a tapered reamer to reshape both the new metal and old metal. Then after final mud and finish before color.
I sure wish your suggestion were an option. The CA95 pistons cannot be pulled through the upper crankcase. I'm convinced the seized rod is the result of heat & friction and rusting bearings did not help matters. Rust also locked in the piston wrist pins. I had to be careful not to damage the upper case while trying to free up the crankshaft and wrist pins. I tried every trick in the book. After fail after fail, I cut the rod free at the crank and at the piston wrist pins. I'll source another crankshaft as well as new pistons. I planned to replace the old pistons with .25 oversize and then send out the cylinders for boring anyway. I don't mind wasting rusted and pitted parts, especially when the rust is on hardened (heat treated) surfaces. I'd try removing the crank with pistons on from the upper case,
