Violet
Hi everyone!
I am stuck, and could use some help figuring out my next steps. I am fixing up a not-so-previously-loved SL 350 K2, and I have had it running multiple times, even drove it for 30 minutes once! Only stopped because the tires were dry rotted and I didn't want to push my luck. The thing I am realizing is, the points timing keeps going out of whack after every short ride. So this is the third time I've gone in to try to fix it, I tightened the bolts down as much as I dare because I don't want to strip them... but I don't think that they're the issue now. Currently, I CAN'T get my points timing set correctly as even at the far extreme of the spectrum my right point is almost an inch off of sparking when it's supposed to (sparks after the mark, if that matters). I will post a pic of the extreme points setup right now so you can see how far I have it adjusted.
A little info, I completely redid the entire electrical system - so the spark is good and the coils / condensers should be good. I have set the cam-chain tensioner and valve clearance. I got the points from 4 into 1, I don't think those are Daiichi, here's the link https://www.ebay.com/itm/173806285751?hash=item2877a973b7:g:AToAAOSwLXBcb0aq
I am stumped! I am also just learning how to work on motorcycles so the more details you include the better.
V
V
