Copyright_47
My tank had been lined by the PO, along with the cap. I dissembled the internals of the cap, scrapping away the lining material and with a a sewing needle, cleared the vent hole in each piece of the cap.
The way the air moves through the line almost makes it look like it's sucking fuel down at a high rate, but maybe the tank really is expelling air through the carb vents.
Easy check. While it's idling like that, open the gas cap and see if anything changes.
It's hard to come up with a solid theory, but maybe the tank is breathing poorly only after a longer ride. What's the level in the tank? I would think that vapor lock would occur more quickly when the volume of air in the tank is smaller.
I wonder if the fuel line you are using is thinner than the standard black Honda 5.5mm line? Or if it provides less heat insulation
I've never run clear fuel lines so I've never seen that activity, but I'm not so sure it's actually the problem either.
It's a different world with gravity feed carbs on an air cooled engine, and these 350 carbs that feed from underneath might be part of it since most Honda carbs from that era feed from above the float bowl.Yeah... I will say after taking that video I let the bike cool down for 30 mins, came back started it up, idle was back to steady healthy 1300 rpm and the fuel lines looked like this:
Pic taken while engine idling, was no bubbling, just steady normal flow.
I have been looking at the carbs where the fuel line connects underneath which I have not seen before and just curious went to CMSNL and ebay to see if these are original carbs. Just doing a short search the carbs I saw feed from the top. Not saying they are not the correct carbs just odd to me.It's a different world with gravity feed carbs on an air cooled engine, and these 350 carbs that feed from underneath might be part of it since most Honda carbs from that era feed from above the float bowl.
Help I received on the form that just might apply to your point arching issue as it was the answer for my case was, that because the frame was powder-coated, the bracket that holds the ignitions was unable to ground to the frame. I had scraped away some of the paint where the bracket comes into contact with the frame at the bolt holes, thus grounding. FSM does not show this as a grounding point. I went the extra mile adding a grounding connection there as well.New coils, no change.
Quite a bit of arcing at points, i'm praying a new condenser might do something.
Yes, I’ve done the same thing on mine.Help I received on the form that just might apply to your point arching issue as it was the answer for my case was, that because the frame was powder-coated, the bracket that holds the ignitions was unable to ground to the frame. I had scraped away some of the paint where the bracket comes into contact with the frame at the bolt holes, thus grounding. FSM does not show this as a grounding point. I went the extra mile adding a grounding connection there as well.
off idle response is perfect. the bike runs perfect in every other way except for the idle.How is the off idle response when the motor is fully warm? Is that the issue or is it simply idling low enough that it will stall?
I suppose this could explain whats going on here, particularly on the left cylinder. I'll check for a leak when cold/warming up.If the air leak closes when the motor is warm then you'd be rich.
The combination of the things you describe makes me wonder if the left cylinder is firing intermittently at idle after the motor heats up, possibly due to fouling of the plug or a bad electrical connection somewhere.I still think somethings up with the left cylinder, during warmup the left and right exhaust pressures are equal but at full temp when the idle starts sagging, the left exhaust pressure is noticeably weaker than the right. If I try to boost the idle speed on the left cylinder to compensate, the next time I start the bike up the left exhaust pressure will be higher than the right, and the idle hits like 1600-1700 during warmup before it starts slowly sagging down to below 1k at full temp.
I'm not convinced there's a connection between the idle drop of 100 rpm and the headlight on. These charging systems go backwards at idle anyway and because they are discharging, I'm not sure it would add any "load" to the alternator that would cause the dip - seems to me that it would have to be charging at idle, like a car alternator can/does, and then adding load might cause a drop in rpm. Could be just the lowered system voltage at idle might influence the spark strength and cause it, but I'm not sure that slight change would do it either. I just wonder if your carbs are just slightly worn enough that there are some small inconsistencies upon return to idle. Alternatively, you could raise the idle speed about 100 rpm and it shouldn't cause problems returning to idle, then when it gets fully warmed after a long ride maybe it doesn't stall, just droops a bit. IIRC the book idle speed is +/- 100 rpmHonestly I would be content if could have that 100 rpm back that the headlight is stealing from me. Is that dip normal? Considering the battery is fully charged, the charging system output is strong at 5k rpm (14.5+v), what could be amiss here... would a modern reg/rec help bolster electrical output at idle?
Yeah its like its just slowly getting choked out or starved. Wouldn't it be a little more obvious if the left cylinder were really dropping out entirely? Like wouldn't I feel the left cylinder spring to life with a little throttle, and just a rougher idle in general. I'd be more inclined to think its just slowly losing power but still firing.The fact that you can increase the idle during warmup but it still drops below 1000 rpm is really odd.
No, I can try that. The connections seem good. Brand new NGK caps and coils.Have you tried jiggling the spark plug cap or even removing it (on the left)? Checked the cap to wire connections?
Clearances on the loose side of spec, just a little grabbing on the feeler gauges. I was thinking about adding an extra .01mm. Cause I know idle is way more sensitive to valve leakage than higher rpm operation.What about the valve clearances? Are they maybe too tight on the left?
Have not checked cold compression, I will do that.Is there a big difference between cold/warm compression numbers on that cylinder?
No but I replaced the coils with new ones last week and saw no difference.Have you swapped the coils to see if one might be failing when warm?
Yes, bike runs absolutely perfect in every other way.And I think you already answered this question, but even when the idle is sagging, the off idle response is still good?
I agree with what you're saying here and I trust your assessment, since you have hands on the bike. It's just something I would want to feel myself it were my bike.Wouldn't it be a little more obvious if the left cylinder were really dropping out entirely? Like wouldn't I feel the left cylinder spring to life with a little throttle, and just a rougher idle in general. I'd be more inclined to think its just slowly losing power but still firing.
Throttle wide open?So a drop of 10 psi in both cylinders at full temp. Thats peculiar, compression is supposed to go up with temp, not down.
Throttle wide open?
That is interesting
It's a shame because you could have bought 1st over rings and filed them to just above minimum end gap, but hindsight is always 20/20.There does seem to be a good bit of white smoke coming out of the breather tube when engine is hot, indicating blowby. I remember when checking the ring gap on the new rings I bought from 4into1, they were at .016" which is the upper bound of the 'standard value' listed in the FSM (.008"-.016"). I didn't like that, But its in spec.
Which will have nothing to do with your compression readings, if the actual fire ring portion of the head gasket was leaking you'd know.There is also of course the compromised head gasket leaking oil everywhere
You can get some pretty ridiculous numbers by adding too much oil. Should only need a capful or less from a quart of oil. I don't trust that 193 as meaning much right now.
I wouldn't be inclined to rebuild or get too concerned by those hot/could numbers for the time being, but I would second Mike's suggestion to try slightly looser valve clearances as a test.
To me, that's a lot of smoke, but I defer to those with longer resumes. Do you see it from the pipes as well? Are you able to measure the head temperature?What do yall think of this smoke?
Yes and yes. Also can see lots of oil splashing around if I take off a tappet cover.Did you ever confirm oil flow to the top end by removing the check bolt on the points side of the head? Oil level is good?
