TomatoThePotato
Hey y'all, just joined this community, happy to be apart of it. New to working on bikes but wanted to start somewhere and learn.
So, my CM450E was working perfectly fine until I decided to refill it with some 91 Octane Gasoline. The bike was running smoothly back from the gas station until I realized it was back firing a little bit and noticed a big pool of gasoline coming from one side of the overflow tubes. I did some research and people were saying that my float needle was stuck which was causing the gasoline to leak out. Okay great. I also heard that you can spray some compressed air into the tube and it should fix the float needle, however, I was already planning on rebuilding the carbs anyway and had a carb rebuild kit on me. However what I didn't notice that it was for a 1982 Honda CM450E and not the 1984 model (also for some reason Honda says there were no 1984 CM450E models which is weird). From what it looks like, it still works with the VB22 carburetor but I noticed the needle is slightly different. I don't know exactly what needle my CM450E has since I haven't taken it apart (haven't got the time to just because of school) but I wanted to know if anyone here has worked on specifically the 1984 model. Could the needle I have still work? I had received a bunch of other jets as well, will those be interchangeable with the VB22 carb I have? If I am missing context, let me know! Also any advice for a first time carb rebuild will be much appreciated - no matter how basic/obvious or complicated. I'm here to learn.
<-- The float needle that I have gotten
<-- what I think my CM450E has.
I have also attached a link for the carb rebuild kit I have bought if that gives any extra information that can help you help me.
Thanks again
<-- what I think my CM450E has.I have also attached a link for the carb rebuild kit I have bought if that gives any extra information that can help you help me.
Thanks again
