Spent a little time in the garage today even though I was supposed to be working on other projects - that was the deal for the purchase.
I been gathering info on the C77 and have been doing a bit of reading in the manuals. We know that these manuals sometimes have errors but I've read a few things that loose a little in the translation. As an example, here is an excerpt from the FSM when talking about the C77 frame construction:
I also found in the FSM that if you are looking for frame related assembly/disassembly information that you should reference the CA95 manual as the parts are similar. There is very little in the C77 FSM for the frame.
I removed the luggage rack and the sissy bar today. I think I will keep the rack but drop the sissy bar. I put a little Mother's chrome polish on the luggage rack to see how it would clean up. With a lot of effort I think it will come back very nicely.
I moved on to the battery area and took it apart so I could get at the air filter. Looks like there was a house guest in there for many years.
The FSM says to reach in between the frame and disconnect the tube connecting the filter and the carb - yeah right. I could get maybe two fingers near the clip but that was it.
I went to the coil side and removed the coils and the HT leads to give myself more room behind the carb.
I was able to disconnect the tube from the carb end. Luckily the tube was still pliable, so I was able to disconnect the air filter end by pushing the tube off the air filter with a screw driver.
Once the air filter was out, I took out handfuls of looks like burlap plus an inch thick layer of poop and pee from the bottom of the frame under the air filter.
The filter and tube are toast but I seem to remember seeing them for sale by vendors in Thailand. Has anyone dealt with these vendors, is the quality good?
I took the carb off but the slide is frozen in the carb body so I can't disconnect the throttle cable. I doused the area with liberal amounts of PB Blaster and I will let that soak overnight.
Might be a while before I get back to this as there is another house project waiting in the wings and the materials were delivered this morning so no more excuses.
