Danager4792
If I remember correctly, the throttle plates between the 14h & 723A have different numbers stamped on them. Not sure what the numbers represent though. Maybe main jet size?
Maybe size of the little bypass flaps? no se... I may need to look, I know the linkage all is the same, I'm not sure I looked at the plates outside of them fitting the same in each carb. I guess stuff like "uh... this doesn't belong on this bike" isn't really covered under the FSM.If I remember correctly, the throttle plates between the 14h & 723A have different numbers stamped on them. Not sure what the numbers represent though. Maybe main jet size?
You’ll be able to verify, but I remember the 723A throttle plate stamped 145, and the other 14H carb said 130. Both of those are the main jet sizes for the carbs, is the only relation I can make.Maybe size of the little bypass flaps? no se... I may need to look, I know the linkage all is the same, I'm not sure I looked at the throttle plates outside of them fitting the same in each carb. I guess stuff like "uh... this doesn't belong on this bike" isn't really covered under the FSM.
That does sound like a very reasonable hypothesis - and something I'd totally have wrong! It would make sense though that the 723 would have an fractionally larger opening to mix properly with the richer jetting. Carbs are still off the bike from the engine rebuild, along with a bajillion spare parts in the CV carb box. If that is the case, at least it's the choke plate and not the throttle plate. Choke plate is easy to swap around.You’ll be able to verify, but I remember the 723A throttle plate stamped 145, and the other 14H carb said 130. Both of those are the main jet sizes for the carbs, is the only relation I can make.
If I happen to have both throttle plates in my spare carb parts box, I’ll measure them with a digital caliper and compare.That does sound like a very reasonable hypothesis - and something I'd totally have wrong! It would make sense though that the 723 would have a fractionally larger opening to mix properly with the richer jetting. Carbs are still off the bike from the engine rebuild, along with a bajillion spare parts in the CV carb box. If that is the case, at least it's the choke plate and not the throttle plate. Choke plate is easy to swap around.
Those were the correct numbers… 130 and 100. Not 145. Would you be able to measure them and compare?Got the brass caps off the one I am salvaging bits from using both heat and pliers as gently as I could. Pressing around the cap helped although I ended up squeezing one a bit out of round but still usable and I think I will only need one. I checked the numbers on the throttle plates and all 3 of the 723A's have 100 stamped on them and 14H has 130.
With my memory I need all the help I can get. It would have been nice if they had stamped the main jet size on the throttle plate for a reference number.My apologies for my shady memory in regards to the numbers on the throttle plates. Just wanted to be sure you guys put in the correct throttle plates that were “intended” for the 723A’s.
The way I gave myself permission to go ahead and soak them anyway was that the washers are actually made out of felt, and I decided felt wouldn't be harmed by a detergent/solvent. The oil or grease that helped seal the felt would come out, but that I could replace,and I did.I have a question, will soaking the carburetor bodies in Berrymans carb cleaner mess up the felt washers on the choke and throttle plate shafts? Also an interesting observation that on both 723A carburetors, one off the project and the other from the donor, the washer that goes between the spring and o ring on the air screw/idle mixture screw was missing. O ring not going to last long with out that washer.
I had about talked myself in to just soaking the bodies and the worse that could happen is it would wash out some crud from the felt but uneasy that something "bad" could happen. I will do like you said and re-oil the felt after cleaning and it dries. I am lucky on the carb that came off the bike I am using that the insides are actually much cleaner than the outside. I think someone actually drained the fuel out of the bowl the last time it was put up back in the 80's. The outside is nasty as I think it was directly under a mouse family outhouse for all those years but it is cleaning up. Got the all the brass out by soaking in Kroil overnight and both carbs have 38 idle and 145 main jets. Ordered Honda gasket sets, needle and seats and screw sets A which has new idle speed and mixture screws and such from Partzilla. Next step a meticulous cleaning of the the jets, emulsion tubes and orifices. I purchased a set of guitar strings from Amazon as I had seen that is the tool of choice to clean these parts. I wish I was ordering them for a guitar but the only musical instrument I can play is the radio.The way I gave myself permission to go ahead and soak them anyway was that the washers are actually made out of felt, and I decided felt wouldn't be harmed by a detergent/solvent. The oil or grease that helped seal the felt would come out, but that I could replace,and I did.
As for the washer between the spring and o-ring, it's like a lot of other small parts that were sucked into the vacuum of ignorance brought to the bike by prior owners.
If you have a hobby shop close by that sells model stuff they will normally have a bag of small metal washers that are the correct size. Use the original to compare to the ones they sell. I bought some locally years ago since PO’s don’t have the knowledge of what was in there originally.I have a question, will soaking the carburetor bodies in Berrymans carb cleaner mess up the felt washers on the choke and throttle plate shafts? Also an interesting observation that on both 723A carburetors, one off the project and the other from the donor, the washer that goes between the spring and o ring on the air screw/idle mixture screw was missing. O ring not going to last long with out that washer.
Just soaked in the carb cleaner and scrubbed a bit with a parts cleaning brush and some blue scotch brite pad. Luckily the carbs were actually quite clean on the inside.Everything looks very clean - especially the carb bodies. Did you do anything to them, other than soak them?
Thanks foff TV the tip on the hobby shop and I may have to check into it if I have issues getting the screw sets. Keyster carb kits have them as well if I have to go that route.If you have a hobby shop close by that sells model stuff they will normally have a bag of small metal washers that are the correct size. Use the original to compare to the ones they sell. I bought some locally years ago since PO’s don’t have the knowledge of what was in there originally.
Not using it will cause the spring to chew into the O ring, so it really needs to be in there to seal the circuit properly.
I have the genuine Honda Gasket sets, Valve Sets, Float (Needles and Seats) on order from Partzilla as well as the Screw Set A which I need be cause the throttle stop screws and springs are very badly rusted from years of mouse urine.Also, if you need new float bowl gaskets. be sure you order genuine Honda. I tried 4into1's kits and the gasket never sealed properly. It was slightly too small and thin. Once I went genuine Honda, they fit perfectly. These also come with the small rubber o-ring bits.
LOL, everything we deal with is old, like most of us....especially on older models.
Hopefully you already used up the balance on that gift card, not sure they'd redeem it in the present condition.I also used the gift card template he sent an image of to make a float gauge and set the floats.
Clean that rectifier up and use it as a paperweight, and remove the regulator from the bottom of the battery box too. Get a Sparck Moto rec/reg combo unit if you haven't already, it's the best way to go (and the least expensive way to get there).I need to bench test the solenoid and other electrics just to see if anything can be salvaged.
For that price I am sure I will go that route. The main harness is pretty rough and I had already decided to buy a new harness from them so I wouldn't have to chase gremlins.Clean that rectifier up and use it as a paperweight, and remove the regulator from the bottom of the battery box too. Get a Sparck Moto rec/reg combo unit if you haven't already, it's the best way to go (and the least expensive way to get there).
12V Single Phase Regulator/Rectifier - Sparck Moto
Sparck Moto - Modern Gear for your Vintage Ridewww.sparckmoto.com
Glad you got it out. You'll want to replace the shoes since it's obvious they've been exposed to a lot of dampness. Shoes exposed to high levels of dampness will start to corrode the aluminum frames and cause the linings to delaminate.Thanks Tom the arm is locked tight and I did dribble Kroil along the opening but got the plate out after thinking about it a little longer took a 10 inch length of 1/2 inch PEX pipe and used as a drift along the edge of the backing plate and after a bit it started coming out. Although locked up the backing plate and shoes not really in that bad of shape although I am sure it will present new challenges. I like PEX over PVC as it is a bit softer so not as likely to damage what I am hammering on.
Thank you for the suggestion but thankfully I was able to get it apart relatively easily. I just need to needed to step back and try another approach. I really didn't want to break anything.I wrote the next paragraph before it dawned on me that you might have gotten them fully apart. If you did, congratulations! If not, here's my thought.
The inside of the brake drum is probably rusty and dragging on the brake shoes. There's really nothing else I can think of holding the backing plate on. If it's all clean and correct it really just falls off, usually on my foot. I'd try to rotate the plate, many rig up a breaker bar with a socket that fits into the axle hole and put a strong, longer bolt through the hole where the stopper arm bolts up. Then you can get good leverage to rotate the backing plate while maybe someone else stands on the tire while it's laying flat on the floor.
Hey Tom just wanted to post a cautionary picture of the hazards of using old brake shoes no matter how good they look. The brake lining separated from the shoe with just a tap of a plastic mallet on the shoe itself when I was trying to get it to rotate on the pivot.You'll want to replace the shoes since it's obvious they've been exposed to a lot of dampness.
Yep, not at all surprised after seeing how crusty that brake panel looked once you got it out of the drum. Life would get really ugly in a hurry with shoes in that condition. I have a picture much like that.Hey Tom just wanted to post a cautionary picture of the hazards of using old brake shoes no matter how good they look. The brake lining separated from the shoe with just a tap of a plastic mallet on the shoe itself when I was trying to get it to rotate on the pivot.
