Here in Alberta this stuff has always been very simple for me. If I present a bill of sale with a serial number of bike that isn't currently in the system then I need to have an Out Of Province inspection done by certified motorcycle mechanic and then I'm good to go. I have done this with bikes that have sat in sheds for decades and also with newish bikes that I've bought in other jurisdictions, it doesn't matter.So the ownership that Chris has is incorrect. Surprise! It has the hinkey motor serial number not the frame number so it will not fly with an insurance company. He could keep it as is if he didn't expect to ride the bike. Service Ontario will continue to change over the past to present owners no problem.
My previous 1968 CL175K0 had the same issue. So I asked Chris to send me a copy to compare to the CL160 frame. It seems back in the 60's when first registered it was easier to locate and read the motor VIN vs the frame stamped one. Rules were much more relaxed back then it appears, with no strict guidelines.
Troy,Here in Alberta this stuff has always been very simple for me. If I present a bill of sale with a serial number of bike that isn't currently in the system then I need to have an Out Of Province inspection done by certified motorcycle mechanic and then I'm good to go. I have done this with bikes that have sat in sheds for decades and also with newish bikes that I've bought in other jurisdictions, it doesn't matter.
So in the case that you are describing I would present a Bill of Sale with the frame serial number on it and have it inspected. Viola, it's registered and it seems so simple compared to the hassles in US jurisdictions.
Turn it 180 degrees?A few items received one from Chris Crawford which was the NLA rear brake cable frame standoff. It cleaned up well and I am working on rejuvenating the rubber donut which holds the cable mid point on the frame.
I am missing the main stand spring which is NLA from a reasonably priced vendor. I found one at a US vendor for $25 + $15 US shipping which is about $60 Canadian for a spring. I have a shorter used one in my stock which I modified to fit, yet it is too short and the stand is under too much spring tension.
If anyone has one or a line on one that isn't a silly price, then please reach out to me with a option.
Cable Standoff - Thank you Chris C
Rear main stand spring mod which really needs a stock spring on the part. Totally out of position here with stand vertical to frame.
So the stand is vertical at 12 o'clock and it could never be there with the swing arm in place. I use this option when I am installing the spring if the frame is stripped down, as it allows you to install it with no tension. Once you bend the stand down to the 9 o'clock or 8 o'clock position where it would normally be positioned. It seems like it is really too tight.Looks fine to me in the picture. When "relaxed" most bike will have the spring under some tension and I'm not seeing a lot of air between the coils.
Flying do you mind sharing your method of rejuvenating rubber parts ??? I have this exact part that I’m trying to save for my 160 !A few items received one from Chris Crawford which was the NLA rear brake cable frame standoff. It cleaned up well and I am working on rejuvenating the rubber donut which holds the cable mid point on the frame.
Yep found that one and its only $350+ Canadian landed. It is the only correct one on EBay presently. I think I have the CB version of the main stand. Which is a different design, since the left muffler usually has a bumper on the bottom section to catch the one arm of the main stand.If I were a betting man - I would say that the top hole in this pic is for a bumper
I just use any product that is from say McGuire's or any other company that is touted for rubber products and rejuvenation? I use a number of applications to help it along. Frankly on 59 year old rubber there is only so much you can do. This rubber is shedding a black colour every time I apply the solution., so it has seen better days.Flying do you mind sharing your method of rejuvenating rubber parts ??? I have this exact part that I’m trying to save for my 160 !
That's the plan. I am no welder and there are a number of custom weld jobs needed on this bike, so add more $$ for Chris. This build is way underwater and it isn't in the home stretch yet. I recently also found a few clutch metal plates that are scored and warped.So just weld a tab on the one you have?
Mine was pretty bad. It was off the bracket and I used a flat head countersunk wood thread screw from inside the bracket and the split loop got reinforced with fine copper wire then a coat of either shoegoo or black liquid tape.Flying do you mind sharing your method of rejuvenating rubber parts ??? I have this exact part that I’m trying to save for my 160 !
Nah,No time like the present to learn if people are paying you to do stuff like this. Plus side is that the factory welds look like a learning disabled monkey did most of them, so there isn't a high bar.
I just spent some time measuring the place to put a correctly fabricated new tab on the upper rear CB stand at the right angle. I have in stock the correct style of rubber bumper in a aftermarket part. It maybe not the same thickness as the one Honda used. I compensated for the rubber thickness, since mine is just a 1/4" thick once pressed through the hole on the new bracket.The rubber bumper hits the rear of the main frame downtube. I put a CB stand on My cl160, welded a short length of one inch square tubing on the rear side of the stand, trimmed away the part I didn't need to form a tab on backside. The rubber bumper I used was a car part from the local parts store.
Tom,Perhaps someone with a real CL centerstand can post a pic of the up position stopper. The Benly stand has some frame to hit the stopper bracket on but these 160s don't have much down there. My CB160 only hits the muffler with a rubber band on the side extension.
Pardon my DIY side stand add on. Looks like the center stand spring is longer also.
Yes the picture oldjeep posted in post 115 is the correct NOS CL160 stand at a cool $350+ Canadian on EBay presently.Makes sense that Honda just welded on that additional plate with the semi-grove and must've added a bar to the centerstand.
I think that was a CA95 stand. It may have come from a CA160, but both are a different animal.Yes the picture oldjeep posted in post 115 is the correct NOS CL160 stand at a cool $350+ Canadian on EBay presently.![]()
Tom,I think that was a CA95 stand. It may have come from a CA160, but both are a different animal.
I'd have to do some digging to measure and see if that is even possible. It wouldn't need that monster side extension to clear downpipes.
As Mike in Idaho said, use a CB160 stand and add whatever bracket it needs.
I remembered reading that using grease isn't the best idea because of the thickness and oil flow, and I also remembered seeing (I think) Bill Lane show that rubber band trick and fortunately it stuck in my head.I dropped my rollers too and used sticky grease to reassemble, Ancientdad had a good rubber band trick to do his.
Good tip on the vaseline. It's been a while but I think I just used regular bearing grease and followed with generous red assembly lube oil to help disperse the grease.For applications where the grease is just temp glue - Vaseline works great. I use it in automatic transmission applications mainly to hold balls in the valve bodies the oil will integrate it easily.
I was getting a slight bubbling on the big end conn rods when I used a WD40 straw can inserted into the two middle bearing oil holes. This was prior to this 5-6 day soak. The issue was the side flow out of those bearings was where most of the WD 40 was exiting on the side away from the journal webbing.Good tip on the vaseline. It's been a while but I think I just used regular bearing grease and followed with generous red assembly lube oil to help disperse the grease.
Back to crank cleaning;
Short of containing pressured air to back blow the grit, or access to mechanically dig it out, a giant ultrasonic bath may be useful, perhaps filled with Evaporust.
Teebo used an aquarium type pump, but he had better access on his 450 crank.
Looks like rust and some dirt. I'd use Evaporust or Rust911 solution. A large ultrasonic would be nice or even a cheap battery powered sex toy in a zip lock thrown in.After a 7 day soak in kerosene for the crank the bottom of the container had quite a bit more dirt again. I blew compressed air into the two centre bearings and no joy for any exit on the conn rod big ends. I tried standing it upright and no change which was a bit disappointing. So I sealed the outer part of those two inner bearings with shop towel as best I could. I then sprayed some WD40 around the conn rods to wet them and blew compressed air into the bearing holes.
There was some bubbling from each conn rod each time I tried that procedure. The easiest exit for the oil feed into the conn rods will be out the open side of the bearing that I sealed up for the test. So unless the passageways are still partially blocked, it appears the conn rods only get a small amount of oil feed.
Here is the extra dirt that came out of the crank which is about 50% more than I got on the first 2 day cleaning that I did previously.
I did actually have the picture and got it right this time. You maybe right on the fitment. There is a notch on the one case section that I did have the plug in slightly differently up against the notch and it seemed OK. My pictures of the engine teardown did show it in this current position, so I am good to go.Looks like the plug would only fit the one way?
