Yeah, I was a bit surprised to find 4 different pictures of 4 different parts for that same part number.Yeah, eBay sellers can rarely be trusted for correct part number application, but you'd expect better from NOS Parts Now.
Thanks for the input AD. I would say that Chris is glad that part ins't missing, given the US costs of those items.I'd suspect the torque value is wrong as well, but the bearings and spacers are designed to tighten up the centers of everything in between while allowing proper movement of the wheel on the bearings. The spacer in the speedo drive unit should provide the right contact in the center to tighten against the inner race so the body of it sits still while the interior parts rotate. That drive unit looks suspiciously like the CB77 and DOHC 450 speedo drive, are you certain it's from the 160?
CB160
BOX SPEED GEAR for Honda - order at CMSNL
✓ Good to order: BOX SPEED GEAR ✓ Manufacturer Part Number: 44800-216-000 ✓ Quality partwww.cmsnl.com
CB77
BOX SPEEDO GEAR for Honda - order at CMSNL
✓ Good to order: BOX SPEEDO GEAR ✓ Manufacturer Part Number: 44800-268-020 ✓ Quality partwww.cmsnl.com
CB450K2 (last drum brake model)
✓ Good to order: BOX SPEEDO GEAR ✓ Manufacturer Part Number: 44800-283-000 ✓ Quality partwww.cmsnl.com
That is not the right solution, it's like putting loctite on a bolt that you can't tighten as fully as it should be because the parts don't fit right.I think I will tighten the axle castle nut to about 15 ft lbs and the cable will hold the speedo drive in place.
Yakeye: Thanks for the correct pics. I was able to download and print them for the binder I have for the bike.Flying , reading the above I realized I have a CL160 parts catalog!!! It shows the aluminum fork lowers not the steel. Shows an axle spacer with flange on both sides ; part #44311-216-000. One appears to be available at NOS Parts now. Maybe this will help sort front wheel?View attachment 53388
View attachment 53389View attachment 53390
No bearing replacement on the front wheel. I did replace a rear wheel bearing on one side of that hub.. You can see the original factory stake marks on the 3 screws on one side of that hub with the #9 part held in with 3 screws. So that side I am sure is a factory bearing untouched.Did you replace the wheel bearings? If so and you still have the old ones - put a caliper on them and check width. 15-20lbs is insanely light for an axle bolt
I’ve got an extra I think. After having to combine both sets of forks into one usable set, the other bike is getting a CMX250 front end. Leaves me with a spare wheel - let me see what kind of condition that Speedo plate is in.Good eye there the top cut grooves are indeed pushed inward and there is an inside ledge below each one. The damage may not be the cause of the issue though as none of that damaged area contacts any part of the drive body. Unless there is internal damage inside the speedo drive. It seems to operate smoothly though.
I have contacted a fellow who is a member here in Canada and has a load of CL77 parts for sale on Marketplace. If he has the bearing cover and the CL77 drive unit I will buy both and replace those parts.
I am still stumped as to why this unit and wheel are acting the way they are.
I should be able to get to it tonight. The speedo is in the spare parts bin - let me clean it up and check if it’s operational.Pete if you have both the plate and speedo I need both of them. Let me know what you have available when you get a chance please. I do have an extra side stand with a very slight bend in it at the bottom if your looking for one of those still?
Thank's Pete anything will help here I think. I can arrange to have you just ship it within the USA to simplify it.I should be able to get to it tonight. The speedo is in the spare parts bin - let me clean it up and check if it’s operational.
Thanks Pete that will help for sure. Don't care about clean..... that's the cats job.View attachment 53508
At the very least, the plates in good shape. Let me clean them up a bit but shoot me a PM with the address.
I am not disassembling it since the seal is likely going to be damaged and I don't see a part number to replace it. I have taken a few newer ones apart and yes there are shims on the backside of the gear. How did you get the seal out without damage?When dis-assembling speedo drive pay attention to number and location of very thin shims under crown gear of speedo. IIRC, there was 2 or more.
They are dry seals yet with all the issues this bike has presented in the build. I am just being extra cautious and sealing those areas too. I used green grease for the lube around the different shafts, since it was on the desk already where I did the buildFlyin, do you have some extra sealant around your oil seals in the above photo?? I have always just put them in place dry except oil on the inner opening lip and the shaft. Am I missing something I should be doing???
It never hurts to put some Hondabond on the outer perimeter of the clutch rod seal since they can be known to blow out sometimes and make a huge oil loss in seconds, that's kinda what it looks like to me.Flyin, do you have some extra sealant around your oil seals in the above photo?? I have always just put them in place dry except oil on the inner opening lip and the shaft. Am I missing something I should be doing???
All looks very good!! What rear shocks are those that you have installed??One small job finished with the installation of the rear brake lever and the rear brake cable and a fabrication of the missing brake switch spring. I have the standoff for the rear brake cable to the frame. Since I covered the old brake cable sheathing with a heat shrink tubing with an internal glue base. I cannot get the hole in the standoff to fit over the cable now. The rubber standoff part is hard rubber now with zero flex and I don't want to break it so the cable lays against the frame OK.
The missing rear brake switch spring was fabricated after a number of tries from a stiffer shorter spring. The alignment isn't straight from the switch to the brake pedal attachment. It took some different spring styles and routing to get one that pulled with enough force to activate the switch pull tang.
A box of springs comes in handy in these situations. Princess Auto for the save.
Spring that worked the switch correctly now.
Cable and brake lever assembled.
No clue on the shocks they were on the bike. This bike as you have been following the journey is a bitsa bike. Between missing parts and wrong parts it is a CL160 on the title only.All looks very good!! What rear shocks are those that you have installed??
I have a CL160D. It is a 1968 that I have done a lot of work to over the years. The D models were originally CBs. Because of sales trend at the time Honda offered conversion kits to the dealers to change the CB road bike into a scrambler. This is why the Ds have the electric start. Recently I broght mine out of 49 years of storage. It is alive and well.Pete, I am not really familiar with the model, which is what interested me when he asked for assistance in completing the project. I know the 1968 CL175 Sloper models well, which seem to share quite a number of similar features.
I will see what model he has in the garage tomorrow and what I am getting into here.![]()
