nabs
transmission and crank cases
now the shift forks have arrived I was able to finally reassemble the bottom end of the engine. I checked I could go through all the gears before joining the cases, as demonstrated in this slightly cack handed video:
as the mating surfaces of the crank case are interrupted by the bearings in the transmission Honda could not use a gasket between the upper and bottom cases and instead used a gasket sealant. Here is what I found out when researching gasket sealant:
It seems you should not use a silicon based sealer: apparently it is too squishy and if any sealant squeezes out of the joint inside the case it can break free and block oil-ways in the engine. Instead the recommended product is Hondabond, which is firmer and sets to a sort of malleable but stiff consistency. As far as I can tell the same product is also branded 'yammabond' and ThreeBond. Threebond is available in the UK so I got that.
I could not find out much consistent advice on how to apply it, and the only instruction in the CA95 manual is to 'apply a coat of gasket sealant on the mating surface'. I think coat must mean a 'thin coat' since the two mating surfaces are already machined flat and the sealant is only needs to fill any imperfections left by the machining process.
In the end I decided to follow what I saw on a random youtube video and dabbed it on with my finger. The sealant does seem to go off quite quickly: the Therebond instructions say to fit the parts 'within 1 minute' but I think I took rather longer than that!
As suggested elsewhere I did a test fit first and laid out the variously sized bolts by inserting them into a bit of card matching their location on the cases to speed up fitting.
There was very small amount of squeeze out all around the case so I can confirm that the finger dabbing approach - although perhaps not the text-book way of doing it - is at least idiot proof!
