Yeah that sucks, they should have known better than to sell it like that. Have you sourced another 73mm gasket?Check out that supposedly NOS Rocky 73MM head gasket. Welp, looks like the project was going to take a pause anyway.
I guess, if entering a GFZ but that's where you probably need it.to attach a lockbox for a subcompact CCW
Working on that right now. I was hoping the guy that sold it happened to have another, no dice - he's willing to do a full refund though at least.Yeah that sucks, they should have known better than to sell it like that. Have you sourced another 73mm gasket?
I bet it's still usable if no pits.Working on that right now. I was hoping the guy that sold it happened to have another, no dice - he's willing to do a full refund though at least.
Cometic made a 72mm, 74mm and 75mm MLS gasket for a while, and have seemingly quit producing them (or anything for the 450 for that matter), so now it's finding one of their dealers that still has one of the 75's in stock. The only ones around me really only stock the scarce stuff for these bikes made in Milwaukee . Andrewsmoto is a Cometic dealer, they don't have one on the website, but I'll give them a call since that doesn't mean they don't have one floating around. Thanks for the referral!
After that, it's Capellini - there's one used on Ebay, but nothing new on their site... which means I've got to dig the big torch out of the attic and do the whole quenching bit. It does have the advantage of being reusable with the right care, which may make the most sense long term. Downside is I planed the block, cylinders and head for MLS/Standard gaskets, so I'll have to check tolerances again and make sure that works with copper.
Rocky made one for a while, and given the 3.95 that was the handwritten dealer price on the bag it was in - that was quite a while ago. Can't seem to find any of those out there that look anything different from what I have already.
Which got me to thinking. I wiped it down a little bit and got the gauge out - .95 was what I was getting at about every spot I checked. No compression marks (apart from one spot it looks like it got set on a bolt or something like that). What it appears to be is the finish on the flame ring that basically disintegrated over the years in that bag. I've got half a mind to maybe take some 2500 grit or rock polishing cloth and knock down that finish, put an almost see through ring of gasket sealant on the center of the gasket surface and let that dry for about 45-60 minutes to make sure there's no boogers and just use it for at least the break in period while I look into a custom solution and maybe have a couple made... Another one of those parts that only seem to be getting harder and harder to find.
Yeah. Cometic will produce almost any thickness you want in their MLS and MLX lines. It’s odd that they completely quit supporting the 450 bikes, and still have stuff for other CB/CL models, although it does appear that they’re gearing more and more toward the newer applications.I bet it's still usable if no pits.
AndrewsMS also listed various thicknesses which may help. My old boss used to put a small marble sized ball of soft clay, dumbdumb, he called it, on the crowns to check valve clearance.
I must be confused here. I thought there was a 1 Mil gap around the actual cylinder bore, making the 72 the stock, 73/74 for the slightly oversized bore combos and the 75’s for the +3-4mm bore… after which you’re getting into the complete custom jobsTodd Henning probably still sells oversized Cometic gaskets, I got one with his 74mm pistons for my drag bike engine. If you can't find a 73mm I'd use a 74 rather than 75. I just looked for a way to buy from them and can't find anything but their Earthlink email address, no sales info at their website. Maybe VHT member @Stan Lipert might know where you can get one, he builds very strong 350 race engines.
I've never actually measured the inner diameter of any of the aftermarket head gaskets and never really wondered about it, but the stock gasket is capable of being used up to Honda's S4 (71mm) pistons. So I'd assume the stock gasket is 71mm max. I'll measure my Cometic gasket and a stock gasket later on today and post back what I find.I must be confused here. I thought there was a 1 Mil gap around the actual cylinder bore, making the 72 the stock, 73/74 for the slightly oversized bore combos and the 75’s for the +3-4mm bore… after which you’re getting into the complete custom jobs
Doesn’t fit. Now I could grind down the sides and likely finagle it in there, but the threaded hole doesn’t even fit the end of the cable so then I’m drilling and tapping a new hole. Why?
So I need to figure out if the crankcase cover on the bike is wrong, or the part. Leaning part due to the clutch cable piece, but every time I turn around, something on this bike wasn’t from this bike.
So - does anyone have a spare crankcase cover they can flip over and measure that spot or even eyeball it and see if it looks right.
Either that or anyone have an extra 22875-283-000 to compare the part to?
I feel the same way, but I won't let that feeling keep me from riding. It looks like that eBay cable will cost about $25 including shipping. If you aren't interested, I may scoop it up to replace my missing part.Thanks man. That’s basically the route I was going to go, I just get annoyed by those “fixes” when it’s a visible part. Maybe I’ll just machine down the wrong part to match and add it to the fabrication list.
I’ll DM you to make sure it’s not the same guy I bought from. Misrep on the part itself and basically said “sorry, good luck”.I feel the same way, but I won't let that feeling keep me from riding. It looks like that eBay cable will cost about $25 including shipping. If you aren't interested, I may scoop it up to replace my missing part.
If you bought it on eBay by part number, it's another unfortunate example of how so many eBay sellers don't really know exactly what they have.I’ll DM you to make sure it’s not the same guy I bought from. Misrep on the part itself and basically said “sorry, good luck”.
Thanks. I had mocked one up out of steel stick - luckily the inner channel is the right size so it’s just trimming down the Tabs and widening the hole.I took the measurements (in mm) of the cable locking piece if you go the route of cutting down your existing piece:
sideview, front view,
View attachment 29192 View attachment 29193
bottom plate, inside piece
View attachment 29194 View attachment 29195
If the bearings are even just slightly not square to the head, they jam pretty quickly. A little oil on the head where the bearing slips in helps.Well. Onto the tight exhaust bearing. Everything slid together with no percussive maintenance, so hopefully it’s just in my head here.
You're not trying to put the cam bearings on with the cam positioned at the timing mark, are you? Not trying to be presumptuous here, but slip the cam bearings on in a position where no valves are being opened and once assembled, then rotate the exhaust cam using a screwdriver against the sprocket teeth to turn the cam to the timing mark before setting the head on the cylinder studs.Well. Onto the tight exhaust bearing. Everything slid together with no percussive maintenance, so hopefully it’s just in my head here.
Oh no. Followers are laid as flat as they get, then lay in the cam - I kind of have to kind of roll the right side in or go from the top left handed to get the right angle to lay the cam in at low point (all valves closed, lobes of the cam at their minimal contact depth, slide that points cap on. Cam is now in the races and should be able to be fairly easily rotated maybe 20ish degrees (never really measured it, but you know what I mean) before the cam lobes begin to engage. It’s in the “free spin” area that the right side doesn’t feel like it wants to run as easily as the left.You're not trying to put the cam bearings on with the cam positioned at the timing mark, are you? Not trying to be presumptuous here, but slip the cam bearings on in a position where no valves are being opened and once assembled, then rotate the exhaust cam using a screwdriver against the sprocket teeth to turn the cam to the timing mark before setting the head on the cylinder studs.
Speaking of the intake cam, did you make sure the oil restriction plug in it is on the right side of the head? (as sitting on the bike, of course)That’s a definite possibility, but I know I was frustrated when I was putting them in, had to take the intake out anyway for the missed cam chain roller… trying to eliminate a possible bonehead move.
Turns out the seal on that side was the cause. Little too much assembly lube and it had slipped a bit at an angle to the shaft. Easy fix, and good to know I'm not crazy.
You can slip a short probe into the back end of the tensioner body to feel how deep the tensioner shaft went when it adjusted.I'd say the tensioner let out 2/3rds-ish of the total throw, but it looks right, feels right, timing marks lined up and everything spins at the same rate.
Honda typically went down the opposite side of the frame for most cables, clutch across to the right side of the steering head and back across to the left under the tank and the throttle across the left side of the steering head. You can go either way as long as it doesn't cause any issues with stop to stop handlebar turns. Since I have Mikunis on my 450 I had to modify a lower half of the throttle cable from a slide carb Honda and it was a bit short, so I ran mine like this. Not fond of the look but I've been to lazy to bother changing it because it works.Does anyone have a picture of where the install point is for the Y junction?
Dude. Sweet find. I found a set locally too and the guy wanted $75. I was really close to buying them just to have a set.Ebay MC 3.0 rings
Back to the 3.0 oversize pistons for a moment. I told you I had a set of these, too, but only 1 had rings. My pistons look new. Today I found new old stock MC brand 3.0 oversize rings on EBay at the link at the top of this post. Not super cheap but what else will work? Anyway I ordered a set. The ad says they have more.
Yes, the one piece oil rings are more challenging once the cylinder is bored beyond 1mm over, the loss of stock taper is almost complete at 3mm over. With my 4mm (S16) oversize pistons, I put the pistons in the cylinders first, leaving the wristpin hole just far enough below the sleeve to insert the pin once I slide the cylinders on the studs. Wristpin clips are difficult then but IMO easier than fighting with the rings when you're like me and won't spend $100 for Honda ring compressors that I'd only use once every 5 to 7 years. But I'll be using teflon buttons in my drag bike engine build so it will be a snap.I will say, the solid iron final ring is a monster to get inside the cylinder.
Interesting though not surprising. I found out about teflon buttons while building my first drag bike using S16 Powroll pistons, they came with the piston set. That engine spent its life turning 10,500 to 11,000 rpm twice a week, run after run and the only time I ever pulled the top end down was to put bigger cams in it along with a fresh set of rings while I was there, so I know they'll hold up.I thought about Teflon buttons, we used to use those with air-cooled VW race, sand and Baja setups, since you were basically rebuilding those every 10 runs. That would definitely be a significant improvement, although we never took them to the 9000 RPM range, although I'm sure they'd still hold, a 2332 VW crankcase will not.
I just took a look at your solution to this, as I may go the same route - When I trimmed the lower tabs down on that piece I received it feels like there's a lot of flexing going on (granted, that's without the clutch cable tied to the frame at any point, but still doesn't feel solid). Where do you have the wiring from the Generator and Neutral Switch exiting that cover?It does not look like the correct part. Here's a picture of the correct piece from CMSNL. Notice that the lower portion has a different width than the upper portion.
Mine was lost, so I improvised and have been riding without that piece for several years. Sometimes there are used clutch cables available on eBay and the only reason to buy one would be if this part is still attached to it. Here's one.
Yeah, but 260 hp is crazy strong output for one of those engines! By comparison, these twins bottom ends are tough enough to withstand at least a 25% increase in power and still be reliable. I probably made over 1000 runs with my first drag bike, essentially set up exactly as my current street bike is and never had any problems with it despite it being run WFO every time it was run.When we started running TBI and EFI setups with aviation fuel and pressing 260HP, I've sent my fair share of rods halfway down the track.
I'm all ears. TX summer will be here before I know it and I really wanted to do a semi-long cruise down to ROT Rally in Austin and eventually a week-long road trip to Northern CA. Everything is out of the bike and even that crankcase cover is off right now. What's the setup look like?When you're ready, I have a new, higher output, oil pump available.
You won't need any exotic priming pump when you use this pump. A few members here have one in their 450s and I'll be using one in my drag bike engine. Jay's an engineer and spent a lot of time designing it, super easy to install.I'm all ears. TX summer will be here before I know it and I really wanted to do a semi-long cruise down to ROT Rally in Austin and eventually a week-long road trip to Northern CA. Everything is out of the bike and even that crankcase cover is off right now. What's the setup look like?
Thanks. Snapped it up. Luckily the wiring was pretty simple to fix. Just snipping and soldering.I did pick up that used clutch cable so I will be able to go back to stock.
I found another listed for $7 + $7.43 shipping. Here's the link.
Yeah. My buddy took one look at what I had started on, grabbed a beer out of the fridge and stood there until I came to my senses.You won't need any exotic priming pump when you use this pump. A few members here have one in their 450s and I'll be using one in my drag bike engine. Jay's an engineer and spent a lot of time designing it, super easy to install.
Introducing A Better Oil Pump, New For 450 & 500T
This is a multi-part series on a new design oil pump for the 450 & 500T's. Stay tuned, its a fun read, gives some insight into my quirky self and ultimately reveals a new, improved and superior Oil Pump that will bolt-in to your DOHC twin! Part 1, Discovery When I first encountered the small...www.vintagehondatwins.com
Listen, it's not a bad idea and one I've considered (briefly) myself, but the design and connection requirements was more complicated than I wanted to bother with considering the alternatives are so much simpler (proper oil level, to the top of the flat-pressed area of the dipstick which is about a pint more than the factory full mark, and proper warm-up to allow oil flow to the top end even with the stock pump)Yeah. My buddy took one look at what I had started on, grabbed a beer out of the fridge and stood there until I came to my senses.
