OK, your carbs are another version w/o the aircut valves.
If the mixture screws have little effect, you likely need to adjust the idle speed.Hi!
I reinstalled the carburetors and new intake manifolds. The bike seems to be running, there's no backfire, but it still seems to lack acceleration, especially from halfway through the throttle. Turning the mixture screws doesn't help much. After removing the spark plug, when I started one cylinder, even turning the mixture screw all the way in doesn't stall the engine – is this normal? Thank you so much!
Thx, I'm writing in English - so maybye translator do some job. After these huge problems with carbsI hit 'Like' because of the beautiful Polish scenery and the lovely native tongue, too bad I can't understand it.
(which were mainly the result of my limited experience in this area) - I'm finally back on track, although there's still a slight dip between 3000-4000 rpm, but I don't think I can eliminate it. I've never had this in my other Hondas. Cheers!Absolutely sure.Are you sure? That’s not right.?
Please check your PM’s. Post held for moderation.Are you sure? That’s not right.?
