Clutch Cargo
Another question as I chase the 4k RPM stumble. On my SL100, the wiring harness has a very definite set of ground leads. One goes to the battery terminal and the other goes to the frame itself.
Looking at the SL350 wiring, on the bike, there is a lead going to the negative battery terminal, but I don’t see any other lead, in the harness, attached to the frame.
Looking online at the wiring diagram, I see the harness lead to the battery, and what appears to be a stand-alone connection from battery negative to the frame, for ground. However, this may just be the way they drew it vs a physical wire.
Can someone shed some light on proper grounding on a 73 SL350 K2 please?
