tarn
Hi All,
Bought my Nighthawk 450cc 2 years ago, and have done work on the carb but that's about it. My mechanical knowledge is above beginner, but not great so I may be using mislabelling some parts.
I have a hole in the bottom my muffler/cross-over pipe (best photo I took of it, you can slightly see it at the bottom of the photo in the green circle.
I'm trying to take it off so I can weld a patch on it, however I'm struggling to get the whole exhaust system off. It seems to me the easiest way to take it off is to disconnected the nuts from the exhaust mounts onto the frame (another photo), and the exhaust pipe joint nut (see p.86 in the Honda CB450 FSM).
Is there a better way I should be doing this to take the muffler/cross-over pipe off? It seems it's easiest to unscrew those parts mentioned above and pull the whole system forward out of the header.
Thanks in advance.
T
Thanks in advance.
T
