Maraakate
Ahh, my mistake. I'll revise posting.Full advance is 43* +/-2* at 4500-5300 per the FSM. Lazy advance may have you at 6K before full advance takes place
Most people don't know how these bikes are supposed to ride and are surprised when things fall into place. You should verify the timing before you tear your hair out and assume other problems. If you're serious about keeping the bike long term then, in my opinion, spending the $40 for this timing tool will go a long way with diagnostics in the far future. Things do go bad, even with good care and storage and you do have to sort of become your own mechanic to a certain extent with these vintage bikes.
I will say, do not waste time on very cheap timing lights. Reviews tend to conflict on Amazon with their accuracy and viewability. The Innova is the same tool they sell at Autozone, etc. but half the price. It's a good one, I've used it a lot.
Did you take a look at the link about identifying and locating parts in your Welcome Package that I posted in my reply to your introduction? A lot of helpful suggestions in it.Anyone have any leads to valve cover gaskets and the grommets for the bolts? I also need to do my clutch plates and springs. I’d like to get stuff that isn’t an arm and a leg but isn’t horrible quality. Not sure where to look.
Oh yeah, totally forgot about that haha.Did you take a look at the link about identifying and locating parts in your Welcome Package that I posted in my reply to your introduction? A lot of helpful suggestions in it.
At 90 degrees you lose all the leverage of the clutch arm and the bar lever gets really stiff.I know what you mean on the degrees, Imagine a straight line with the bike front to back, the lever is going to be pointing somewhere between 90-120 degrees off that line. My CM400 which has a much snappier clutch feel, is a little over the 110 mark with all the slack taken out, but my CB400 is closer to the 95 degrees you mentioned. the CB has a much softer squishy clutch but no noise and does not slip at high RPM, I also am curious how close to 90degrees can you get before we should consider changing the clutch. If you can't get it adjusted where the noise goes away then you may have to do some dis-assembly.
If you put the bike in gear, pull the clutch and roll it by pushing it around do you still hear the noise?
Sounds good, I’ll order a set and do it.It's a combination of friction disc wear and springs. You're getting close to replacement, 12 o'clock position.
The steels are rarely replaced, only when warped or corroded.What are the odds I could re-use the metal discs / plates and just replace the clutch pads? I’m not sure how this would go considering it’s a wet clutch. I’ve only done car clutches.
Okay good to know, I was totally overthinking then. Thank you for the response. I’m leaking a bit of oil out of the valve cover gasket, I just replaced it. So I’ll have to figure that one out.Unlike an automotive clutch a multiplate wet clutch never fully disengages. It disengages enough to slip, the oil creates a drag friction also while also reducing friction wear. Cold oil will exacerbate the engaged feeling.
When you change a valve cover gasket on these engines, you should always change the bolt seals as well because new ones provide more pressure to help the valve cover gasket to seal its best.I’m leaking a bit of oil out of the valve cover gasket, I just replaced it. So I’ll have to figure that one out.
Haha that’s my dad’s model A, it’s getting a pretty spec’d out supercharged LS. Been doing some odds and ends stuff on it to get ready for the motor to drop in.CB400F bars I assume, and they look good.
We need to see more of that other project.![]()
Well it should run pretty strong with a supercharged LS engine, jeezHaha that’s my dad’s model A, it’s getting a pretty spec’d out supercharged LS. Been doing some odds and ends stuff on it to get ready for the motor to drop in.
Ahhhh I hate to b*tch but that does not sounds like fun.Service manual is your friend, but you will have to disconnect everything in there and remove the turn signal stalks and it will come out. Take pictures as you remove it as everything is in there in a specific way.
Many people think bikes are easy to work on compared to a car because things are smaller. It's simply not true.Ahhhh I hate to b*tch but that does not sounds like fun.
I’ve already spent a good 16 hours prepping my gas tank and it’s still not ready…
Yeahhh hahah, definitely a different animalMany people think bikes are easy to work on compared to a car because things are smaller. It's simply not true.
One way to check things like this is to look at the parts fiches at places like CMSNL, Partzilla and NOS Parts Now. Find the part numbers for both latches and if the middle 3 digit number is the same, then the same part was used on both bikes.Out of curiousity…
Does anyone know if seat latches of an E model (79-81) are the same as the seat latches on a T model (79-81)? My bike is a T, but I have an E tank. I want to get a new lower profile seat for looks, but I wanna make sure it doesn’t ram into the tank like current seat. Wanna insure the latches still line up.
Thanks!
LEVER,R.SEAT LOCK for Honda - order at CMSNL
✓ Get the LEVER,R.SEAT LOCK ✓ Manufacturer Part Number: 77221-447-000 ✓ Quality partwww.cmsnl.com
It would seem so.
The Latches are the same I believe, but the distance between the latches is what you need to verify. I have T models, but the distance between the CB and the CM are different, I would guess that all the CM's for that year range are the same, but to verify someone with and E model frame can measure the distance between the latch mounting holes.
Do you have a gap where the seat meets the tank? Is that what you are trying to solve?
Yeah I was surprised, it looked horrible before. I guess it was just really oxidized.Looks Good! good thing you have some chrome left to polish, mine is almost gone.
To clarify, this could very well be a mixture of very torquey (short) gearing and my noobness to driving motorcycles (this is my first bike).I have noticed, and maybe some of you can help me. This might be wordy so get ready.
When I bought the bike the clutch felt off, like, it engaged and disengaged fine. It honestly didn’t seem like it was slipping either, but the swing of the arm took forever before engagement (as mentioned previously). This resulted in the bike feeling sluggish. Like I was fighting getting it to moving. It also felt like it “lurched” a bit in low rpms, ESPECIALLY gears 1-2 at 15-25mph.
I replaced the clutch, the lever still took forever to swing. Realized the distance between the pusher (idk what it’s called) and the bearing on the spring plate was rather far. I remedied this by making a washer to fit between this gap. This eliminated the lever swing problem. However, the clutch still feels the same. It lurches slightly in low rpms, and it feels like the bike is still kinda underpowered. Gears 1 and 2 feel abnormally slow. 3-5 feel fine. 55mph at 4,800 rpm in 5th.
This has lead me to some theories:
1. The clutch isn’t fully engaging and is slipping very slightly in low rpms (which to me wouldn’t make sense because it drives fine in higher rpms and gears 3-5)
2. There’s a throttle cable issue and it’s engaging harshly, causing it to “lurch” when trying to cruise in low rpms.
3. Transmission issues, which would be beyond my basic knowledge.
I’m not sure what to do, the bike is fun in higher gears at high speeds, cruising and the like. It’s traffic or low speed driving that feel weird. It feels lurchy and sluggish. This isn’t a motor issue I don’t think, it’s synced, carbs function great, revs well, etc. Also, the clutch is loud, like not in a bad sounding way, it’s just loud.
Any help would be great, I know it’s hard to steer me in the right direction when you can’t physically drive it. I hope my explanation helps.
