Richard Pitman
That starter cable worries me. It carries the live feed from the solenoid to the starter motor, not protected by the main fuse. Only live when the starter button is pressed, but potential there for problems if the insulation was damaged as a result of incorrect routing. It should be held in clips under the engine, then routed up behind the engine through the hole in the frame provided for this purpose. Probably an engine out job to do this correctly.
