jensen
Hi,
The last weeks I could work a few hours on the top end. It was a lot more work then expected, especially when you think when using new parts, it would be juts plug and play.
After unpacking the NOS cylinder it was clear that removing the wax would be a time consuming job, the was literately everywhere, even in the oil holes to the top-end. I bought this cylinder many years ago, actually I bought two of them, one in a very good shape (the one I use) and one that was oxidized (the aluminium). I also removed a lot of casting material out of the "air gallery" around the cam-chain tunnel. I decided to buy a new cylinder because standard pistons are really cheap, nobody wants them. Boring and honing wasn't necessary too, so no expenses there. Both cylinders did cost me around 300 euro in total, including shipping. Pistons and rings were 60 euro in total. When looking what I paid for this, I also saw these came from Greece, and I bought them 11 years ago together with a NOS complete generator and rotor.
The air holes around the cam chain tunnel showed a blot of casting material, so much that one hole was completely clogged, there still is casting material in the air flow, but much better then when I started.
I did not yet clean the bores, but you can see the wax in the bore as a yellow / brown layer. I tried several chemicals, one was better then others, but still a lot of work to clean the cylinder.
