dlogreen
Yeah I don't run anything but 89 or 90 Ethanol-Free, so there shouldn't be any sludge in the bowls, but I suppose it could still dry up and create some blockages even without ethanol? I might throw some fuel treatment in there too just in case, while I look around the other stuff.I have a Harbor Freight dynamic light. Works fine and didn't break the bank.
Ethanol can clog up little jets fast if the carbs are left with fuel in the bowls.
I don't *think* a leak at the headers would cause a hang, but improper timing, air leaks, or issues with the advancer could. Carb balance also, but you've not changed the carb synch since it was running good.
I have a HF right by me, like 2 miles, so i'll swing by tomorrow first thing and check. I didn't adjust anything else on the exhaust other than the elbow section and it welded right up earlier today. I'll go back over everything again... double check timing, valves, mixture screws (which I assume could be affected by new better seated exhaust valves), pilots and other carb circuits, throttle idle screw, etc.
Also, never used a dynamic timing light, so i'll be learning that tonight lol while I grill chicken and porkchops on the back porch
