carteredward4
Unless the main harness got pulled and it affected some connections inside the headlight case where all those relevant connections are from the right handlebar switch.
How would I go about testing those connections? I decided to focus on troubleshooting the headlight first. I used a test light and checked for power to the high (dark blue wire) and low beam (white wire) inside the headlight. When the switch was turned to those positions the test light would turn on. I also checked that the bulb is good by removing the light and attaching the ground (green wire) to the negative terminal of the battery and the blue and white wires to the positive. The light bulb seems to be good. Any ideas?
