Cl750MA
Good Morning!
I'm working on building a CB350 "chopper," but its really a '72 CB350 with mix and match parts, and extended front fork tubes/big handlebars.
Just got the frame back from being powder coated- picture for attention!
Anyway, I have to sort out what front end I want to put on this thing now. I'd like a nice clean look that won't require rubber gators. I have what I believe to be a CB175 front end in stock. Is there any reason I shouldn't use this? I'm used to my CB750, and my other 350 scrambler has a pretty rough suspension (for my tastes) as a 6'5" 240 pound middle aged guy. So my gut tells me I should go with something better. The only fly in the ointment is that I powdercoated a CB350 triple tree, that needs the threaded top cap to hold the fork tubes in.
Am I wrong? Is this an SL350 front end? Because if so...I guess my problem is already solved.
So I guess I'm looking for any feedback on this from you guys. If I use a CB350 front end with external springs, will I be able to set it up like this link? Or is that unsafe?
I guess the first question is, what is this front end? Its got 33mm fork tubes on it. Is it an SL350 or 175?
Thanks guys! Looking forward to the feedback...
