1974 CB450 - maintenance, repair, and upgrade log
Sounds like an aging battery that dropped too low and capacity is kaput - I swear these motorcycle batteries are fragile in that regard.
I hope that's all it is. The fact that this brand seems to have vanished from the face of the Earth has me worried about the other two I'm relying on.
My experience is mostly with wet lead acid batteries but if I got 4 years out of one I was very pleased. Most of them usually failed after 2 or 3 years.
I keep pretty good records and before I looked up the purchase date I was *thinking* it was two or three years old. It's going on five and it went through a very harsh winter this year, so I guess I can't complain. Time flies.
I ordered a Motobatt replacement and look forward to favoring this bike for a little while to make up for lost time.
The Motobatt MB12U battery arrived and I installed it along with my spare NOS spark advancer and a fresh set of Nippon Denso W22ES-U sparkplugs (once step hotter than the NGK B8ES plugs I took out).
Both plugs were showing signs of fouling that I believe is related to using off-the-shelf springs on my spark advance. All of the springs I've tested so far yield a much later start for the advance curve and the ignition system doesn't seem to tolerate that very well.
I made a short ride in and around the nearby Tower Grove Park this morning, stopping at the Turkish Pavilion for a photo.
I've been trying to carry my tool roll to ward off mechanical and electrical gremlins, yet twice my left mirror has gotten loose on recent rides. Usually I can fix it by carefully hand-tightening the nut and turning the whole mirror to get it tight at a desired spot, but it came loose a second time today, so I decided to pull out a 14mm wrench and do it right. The tool kit fits in one of my jacket pockets and folds out nicely on the tank.
I had a Yuasa AGM battery in my 750 and got about 7-8 years out of it. I would put it on a tender for a few days each month during winter storage.
It finally gave up the ghost last year and I replaced it with a Duraboost Lithium battery. Much smaller and lighter.
Thanks for the suggestion. I did purchase a battery tender recently and was wondering if it would be sufficient to rotate it amongst my four riders next winter. Sounds like this should work.
That’s exactly what I have done for years. I just go in once in a while and move the tender from bike to bike. It seems to be working out okay.
Watch the amperage output though, if they charge at a half amp or higher it would be too much to leave on for days at a time.
My old charger was a straight ½-Amp NAPA charger, always on when connected. Loaned it out and it has not been returned, so I got one from HF and another from O'Reilly's.
The HF unit charges at ½-Amp, but is microprocessor controlled for battery maintenance. It's so smart that it won't charge a battery that has less than 12 V. This cost only $10, so it'll go in the garage for maintenance duty.
I then bought another charger from O'Reilly's so I can charge a battery that actually needs to be charged. That one seems to produce 0.8 Amps and, if it has a minimum voltage level for operation, it is much more reasonable. I couldn't find any mention of it in the instructions.
