stl360+450
I looked through all of the springs I have and there's nothing left in my assortment that will be better than the ones I've already tried. Mine are all 15mm long or 20mm long. When installed on the advancer, the static spring length is about 21mm. So, the short springs have a high preload that delays the start of the advance curve, while the longer springs have very little preload and have felt a little bouncy/soft off-idle.
I found a company online called Lee Spring and ordered two stainless steel springs with a length of 17.5mm and other physical dimensions that seem appropriate. I also ordered another random set off eBay with 16mm long springs. Will report back with more details once those arrive and I can test them. I'm running the 500T advancer in the interim.
