Kire_Draagsnoj
While servicing the carbs on my CL200 I realized it has 2 right side carbs (so I can't easily access the the intake/valves for synchronization.
Anyone else running 2 of the same carbs?
The bike is new to me as is working on motorcycle engines in general. I can't seem to find a left side carb readily available.
It ran before the tune up (although it would bog down in higher gears which is why I did the tune up). I found and replaced a crack the left side intake manifold.
Also, how the heck do you remove and reset the fuel tank without taking a fuel bath! Tips and tricks appreciated
