Well, I found a wire in my parts bin, that was made up just for such a project. Don't know where I got it from, but has the eyelets on either end and wrapped in conduit. Cool.
Third time has to be the charm. Second inner tube put in must have gotten pinched, but took two days to leak down. I pumped about 50lbs of air in and you can hear air escaping. ****............!!
So took the wheel off, which was a good thing cause the brake actuator was frozen, so had to take care of that. (fixed).
Awaiting the new inner tubes I ordered. Got the little wire installed and it works. The started button works, still think I need a new relay though. I took this one apart and cleaned the contacts, still doesn't seem to work very well. I have a brand new one, but the wire connectors are reversed. So gotta do some wire cuttings. Maybe!
I'm working on other bits of the wiring. Got brake light for front & rear switches. horn, spark to the points, turn signals come on but don't blink, no tail ight.
Haven't hooked the headlight, so can't check that, nor hi/lo beam. Speedo wires not connected, so those little lights haven't been checked either.
Suppose to get 3 inches of snow here in central Georgia today. So sitting in the florida room, watching for it. It's too cold to be out.
Just a teaser photo.
