Trancebuild
So I am now into the electricals on my 73 CB200 build using the existing harness I repaired and cleaned with all tested continuity. I'm unsure on when the running instrument and tailight should be activated.
To complicate it further I am using aftermarket switch controls and have tested successfully Headlight Hi/Lo beam, turn signals, Starter button, Run/kill switch, front/rear brake switches. Seems when the key
is on park I get a hot brown wire and as per one of many wiring diagrams these loop in park mode with brown/white. I get why park mode is needed.
Questions:
1. Is the instrument / tailight suppose to also run when key switch is on? this is not working.
2. As an alternative can I loop the brown / white wire with my switched + black wire as a running instrument / tailight when key is ON?
3. Is it safe to join stator wires yellow and white/yellow when using combined regulator/rectifier and OEM points?
4. Is there an available head scratching imoji
In all fairness to you all a before an after with a birds nest to finish.
Questions:
