C'mon man I thought this was a full service forum! Joking, I really appreciate your reminding me about the post and Google made short work of it. In case any one is curious the MacMaster-Carr part number is 9433k528 - extension springs, corrosion-resistant.Yes, that's the one, post #22. Sorry I didn't have time to look it up for you.
And I do have acetone!it doesn’t necessarily have to be hvac tape. Anything that seals well will do it. HVAC tape just leaves a lot less residue and seals best.
Since you have the caps off, you could just flip It over and throw some acetone in there to see if there’s any leakage. It would be around the perimeter of the plastic window.
Just not installed, I have everything to reassemble if needed. I am going to give the advance unit I have been using one more try and then I may try to swap the springs and such. Just finished setting the points and still need to set the static timing. Putting stuff up for the day to take care of some other chores.No springs with the donor mechanism?
This is my first real tank cleaning and honestly after reading so many trials and tribulations with flash rust I was going to try coating with a mix of a quart of gas and 2 cycle oil and see how it looks but but not very confident. Back around 2000 I tried a clean and coat kit for a 1972 BSA 650 gas tank and seemed to come out OK but ended up selling the project to a guy who wanted it to rebuild with his grandson so who knows if it held up. Kinda wish I had kept the bike but working 2 jobs and no time then. There is a vintage bike shop here in Burlington and I was going to ask the owner about someone to work on the dent removal and and body work so may ask about lining the tank.When I got my CB360 back in 2014, I was trying to salvage everything I could. The paint on the tank was dull, but not too bad and I tried cleaning it with gasoline and a bunch of BBs. It didn't take long for the BBs to start finding new ways out of the tank, which helped me realize that it was a lost cause. Hopefully yours holds up.
My biggest problem with cleaning tanks has been flash rust as well as new rust after cleaning. This led me to line my tanks and I've used both Red Kote and POR-15. What's your plan after the cleaning is done?
It had been soaking for several weeks with the Blaster Metal rescue and has Rust 911 in it now and no evidence of leaks but the real test will be gasoline.Keep an eye on the Metal Rescue to make sure you stop the rust eating process before it goes too far. I left mine too long without checking and it had eaten through the side of the tank. Mine was very rusty, so there was likely not much solid steel left.
I find myself thinking "I've never seen that before" sometimes, but then I have to remember that these things are decades older than they were when I would have said it previously. Good suggestion and good catch.Update on the carbs, per @EzPete's suggestion I checked the plastic plugs in the caps for leakage. I used denatured alcohol and poured a couple of ounces in each cap and the right carb cap leaked immediately which kinda surprised me because it was the side running best. The left cap showed no sign of leakage so I checked the spare 14H cap and it did not leak. I considered running a bead of clear JB Weld around the edge of the plastic plug but decided to clean the cap off the 14 Hand use it. Cleaned up well and the piston works smoothly after using a little 0000 steel wool. Kudos to @EzPete for suggesting I check this because it would have been a significant vacuum leak.
I had already poured out the alcohol out of the cap before taking the picture as it was starting to make a mess. The other caps held fluid for about 15 minutes before I called them good.
That works even better because you would have complete control of the rotation of the rotor. With the heater hose method it does slip occasionally especially if it has picked up some oil which results in some mumbled dag nab its but but a lot better than trying to balance it. If I remember a guy suggested and got me a piece of heater hose from his car when I was trying to time my first CB450 in the parking lot of the barracks at George AFB in the Mojave desert circa 1977 or so. Had a Haynes manual and a test light and profanity if I remember correctly. Thanks for a better suggestion.To hold the rotor in place in a way that makes it easy to adjust I use a screw jack from a car. Put a socket on the center hex on the rotor, and a breaker bar that's at least a foot long, maybe more. Rotate the engine slowly with the breaker bar until you're almost to the place where the rotor is getting ready to jump forward, then put the jack on the floor in front of the engine and then screw it higher until it's just stopping the breaker bar from turning the engine more, press the bar against the top part of the jack and hold it there while you start to screw the jack lower. Keep hanging on to the breaker against the jack and lowering until you get to the mark. At that point the breaker will start pushing by itself and the rotor may move a bit past the mark because of free play in the breaker and socket, and if it does just raise the jack a smidge.
Stop badgering the man, my drag bike project is going on 6 years now!For those of us keeping track at home, is it possible to give a rough estimate of when this vroom vroom machine will move under its own power? Or at least a to-do list?
I gather that the tank and front wheel still need attention. What else?
Perfection takes time, I get it, but I just want to have the checklist so I'll know how close we're getting as things continue to be checked off.Stop badgering the man, my drag bike project is going on 6 years now!![]()
OK you have just given the bike it's name! Custom paint with Vroom Vroom on the sides of the tank comes to mind. Not going for perfection but major things left to do are front and rear wheels and tires, clean the hubs new bearing, new spokes on the rear, replacement front rim bearings and spokes for the front and replacement front fender both due to extreme rust. The fuel tank still needs final dents removed and paint as well as the side covers. My goal is to have it road ready and titled for a late spring or early summer trip back to the mountains with my daughter and son in law and ride the Tail of the Dragon. Of course would need to get it on the road before that to get break in time for both of us to avoid disaster.For those of us keeping track at home, is it possible to give a rough estimate of when this vroom vroom machine will move under its own power? Or at least a to-do list?
Yeah, when I looked it up and saw the 375 middle number I suspected there was enough difference that it was a unique part, but as you said it doesn't mean someone couldn't make one fit depending on what the differences are. It only has the lower brace as well so IMO it looks sleeker that the stock CB450 fender.That's not a bad to-do list.
I looked at the CMSNL listings for the forks and front fender of the 1975 CB500T and they are listed as fitting to CB500 models only. That doesn't mean the fender won't fit, only that you'd have to verify through trial-and-error, via measurements, or from someone else's experience.
I think you saw the thread where Chris pointed out that my bike has some front end elements from a 500T, e.g., gauges and fork ears, but I'm not actually sure about the forks or fender. I think they're 450 parts.
I am late to the party!No chores this morning so decided to finish timing the engine and get the carbs on. Had set the points gaps the other day and got the timing set today no problem but as a suggestion for anyone trying to get the timing marks lined and the rotor jumps I use a piece of heater hose wedged in under the rotor to lock it, still able to turn the rotor but enough friction to hold in place. The bike is slightly raised on the left side to prevent oil from running out and I do prefer using an ohm meter to set the timing over a test light so I don't have to worry about overheating the coils and running the battery down.
After setting the timing and buttoning up the covers I decided to do another compression test and spin the engine over a bit to get the oil up to the top end. Compression tested the same at 160 PSI both cylinders. I went for another engine start and here are the results. Let me know if anyone cannot see the videos. There is a fan in front of the engine but hard to see.
First start, glad I spun the engine up a bit to oil the cams and such.
Eng start1 9-12-25.MOV
drive.google.com
Adjusted the idle speed down a bit and tried again. After it started played with the air mixture screws some as well. You may hear some pops from the exhaust and muffles leaks.
Eng start2 9-12-25.MOV
drive.google.com
Feeling pretty darn good about it so far but need to get the filters on and see if I can fine tune it a bit more. A little closer to the wind!![]()
You should get a sticker made for the lower part of the rear fender under the tag, it would look cool.Better late than never and thank you for all your help getting this far. BTW in case you missed it my bikes name is now "Vroom Vroom" courtesy of Brody!![]()
Well that was easy. But you want something unique though, right?They make them.
That will probably be the last thing on the bike so I have time to find someone to make just the right decal.Well that was easy. But you want something unique though, right?
That's a very flattering statement there Brody, I appreciate it. Unfortunately, I don't have any clearcoat experience as of yet. I would hate for the result to be anything less than perfect. In the back of my head I am open to the challenge though.Rob, what are your plans for painting the tank? Are you going to try to reproduce a Honda color? With reproduction decals? Send it to @Danager4792?
Honestly I was still up in the air about the tank and side covers. I have went back and forth from rattle can to having it professionally done. I am not committed to any color style. Heck I remember looking at the pictures of you 74 450 when you first got it and thinking the black looked darn good. Anyway no decision yet and the tanks and side covers need body work.Rob, what are your plans for painting the tank? Are you going to try to reproduce a Honda color? With reproduction decals? Send it to @Danager4792?
If memory serves the tank you were working on turned out pretty darn good or are you still working on it?That's a very flattering statement there Brody, I appreciate it. Unfortunately, I don't have any clearcoat experience as of yet. I would hate for the result to be anything less than perfect. In the back of my head I am open to the challenge though.
You did a great job with that silver base coat and I'm excited to see how the top coat and clear turns out. You can always wet sand and polish the clear, so as long as you get low humidity I think it's going to be awesome.That's a very flattering statement there Brody, I appreciate it.
I think I'd vote at least for reproduction decals. They produce some sort of authenticity in my opinion, but I think there's room for alternative colors.I am not committed to any color style. Heck I remember looking at the pictures of you 74 450 when you first got it and thinking the black looked darn good.
I'm still in the process of completing the candy orange paint job(three-stage). It's supposedly the most difficult paint job you can do. The top coat(candy) over the silver metallic has to be layered enough to get the color shade that you want. It kind of acts like transparent colored clearcoat. You will be able to see the orange paint, but the underlying coat of silver and metallic will pop through. I have already done my side covers and headlight bucket, I just need to clearcoat them.If memory serves the tank you were working on turned out pretty darn good or are you still working on it?
Gold is definitely my favorite color of the CB450's. My 2nd favorite would be blue, maybe that came on the 750's?One of the original colors that I like is the candy gold with black or white decals. Actually, the white looks a like better to me right now.
Looks like "light ruby red" is the simpler two-stage paint job. Do you have any current pictures of your tank and side covers you could post?Way above my skills. I am not a paint and body person and I don't try to delude myself. My 72 originally was painted light ruby red which is a nice color and I am considering it just for the OEM look with the gold decals.
This is a pic from BAT with a nice example.
I like your color choiceWay above my skills. I am not a paint and body person and I don't try to delude myself. My 72 originally was painted light ruby red which is a nice color and I am considering it just for the OEM look with the gold decals.
And that is a totally impartial endorsement?I like your color choice![]()
