CB450DX
Just went 5h without internet in the middle of a workday, which is also election day right here. ******* great. Well, at least I took my lunch and went for a ride. Still having issues, though.
First: some updates:
Well, my air box looked pretty good, pretty much the same way I left it when I cleaned after buying the bike:
Difference between the filter I was using and the new one (on the right) - Sorry, terrible pic.
Here's how it looked with the new filter, had to press the entire thing down a little bit when assembling the cap/snorkel etc.View attachment 37909
Bike felt pretty much the same after, didn't feel any different.
On setting the mixture: I found it was already set as the idle didn't go any higher no matter how hard I tried. I just returned it to where it was, if just a little bit richer. All is good.
Another thing I've been noticing and stopped now to try to "diagnose" when setting the mixture:
After the bike idles for a few minutes without giving it any throttle, if I give it just a smidge and let it go, the RPM goes down, almost dies, but keeps alive, only happens if you let it idle for a good amount of time without touching the throttle. It doesn't die after I properly set the idle, and when at operating temperature it also barely does it, so I'm OK with it. Setting the mixture seems to have helped with this juuust a little bit.
>I believe this is due to the original ignition coil which has seen better days. The bad one I bought before showed pretty much the same behavior.
I'm going to go to the mechanic and talk to him about checking the stator and everything else, see if he has any other pointers to what could be the issue.
I have found a new sealed Honda CDI (around $100), so pretty expensive at this point (it's the 6th day of the month and I'm almost in the red lol), so I might just pay him the hours to check the wiring and stator before I pull that trigger.
I only put gas at the exact same station where I always got gas for my 66cc 2 stroke, as that little annoying thing is the most sensitive sh#t ever when it comes to bad gas (it will 4 stroke), and even that PoS only ran on premium gas.
But I do know that ethanol ***** with gaskets and that sort of thing, I also always keep my gas tank full to avoid it gathering too much water and stuff and rusting inside. If they pass the law to make the gas be absurdly, unacceptable, mind-boggling 35% ethanol, I won't lie, I might have to sell this bike and accept I lost (and if possible move the **** out of this country)
The primary if I recall correctly was between 0.8ohm and 1.2 ohm (not the greatest multimeter tbh)
The secondary was its issue. It was showing between 14 and 15.5k ohm (service manual tells me it should be 8k, 8.8k ohm max)
The resistance between the 2 pin-plug on the Fiat coil is 1 ohm. (I tried measuring between the spark plug connectors and the pins before, didn't work, weird)
On the spark plug wires, I've just dissected one of them (I bought 4 anyway, barely $10 so it's fine) and it seems that you're right, I don't see any place for a resistor on the cable, so the wire itself is resistant. Interesting, here's a pic of it:
I'll keep in mind to replace these cables down the line, I'll also order some new spark plug terminals as these look like they're pretty terrible.
Man, that's a bummer.Good progress.
The carbs don't have a second stage, they are CV, constant velocity, design. What you're describing with the sudden power surge over 5K is typically the CDI or the stator. Need to test those. It sounds like the timing advance is holding retarded until you get enough rpm to generate a strong enough signal to make it advance.
We have some stabilizers like Motul ones, and some old-school additives (STP) that some people (mostly old folks, to be honest) put in their gas. As I already buy the premium gas, I don't bother with that kind of thing. We have some gasoline with additives at the pump as well but they're not even close to the "Premium Gas" in terms of quality/octane and there's basically also no regulation on which additives they can use, and also how much, so god knows what's on there other than the dye to make them have a different color.Only those who listen to sports/talk shows here in AmericaAnd many if not most of them are also on FM radio now too.
They must be good quality as a brand, lots of drag racers use their magnetos
Wow, we hate having only about 10%. Do you have a product like Sta-Bil available? https://www.goldeagle.com/brands/sta-bil/
LOL, they can certainly become more than you expect, and in a hurry sometimes too.
The current ignition coil on the bike is the original Honda one. I haven't finished making the adapter for the Fiat one yet.You mentioned resistance of plug wires. This means you are using carbon wires. Don't do this, get solid core wires because the automotive wires degrade from constant UV exposure in about a year or two and your bike will start running funny.
What is the primary resistance of that coil? You can measure it by putting a multimeter across the two-pin plug DISCONNECTED FROM CDI.
