Highwayace
Hi everyone,
I am currently in the process of reassembling a CB450 K3 engine and have run into a technical question regarding the valve adjustment.
Does anyone happen to know what the maximum possible valve clearance should be when the adjusting eccentric (cam follower) is turned exactly 180 degrees from the tightest position?
I asked an AI assistant about this, and it suggested a "free" (maximum?) value of 0.25 mm. However, it also admitted that this figure was sourced from various online discussions rather than official factory specifications, so I cannot fully rely on that information. I know the valve clearance (both factory and those guys in Houston; cannot even measure the factory clearance, cannot find tools for that).
I would highly appreciate it if anyone with factory documentation or deep experience with these K-series twins could verify the correct numbers or share their insights.
Thank you in advance for your help!
Best regards,
Ilkka Nyyssonen, Finland
Best regards,
