Windmill John
Okay, I’ve cleaned the caliper, new pads, fluid etc, but fluid still slowly climbs through the centre of the nipple.
I know it will be the seat beneath the nipple and I’ve tried reaming it with a cloth and cross head screw driver. I will try a pencil next, which worked on a float needle seat in the past. I have fitted a new nipple. I may try and clean up the old nipple and retest. If I could find a replacement caliper, then great. Unless anyone knows a great fix for the seating?….
I went in the shed and found a drip on the floor beneath the master cylinder. I’ve already fitted a new o ring beneath the cylinder. No question here really-ish. I’ve put a tissue beneath the cylinder and if it’s coming from the piston, then obviously I’ll replace. Actually a question. Is anyone aware of a replacement master cylinder in the UK?
