New member from portland, CM250C question
Wakabobsama@61
Portland or
Changed tire. Did not mess with hub as it had brand new pads. I don't get it. Brake functions well with finger pressure. I didn't adjust anything. Thank you.
Your problem is how you put the brake cable back in the boss on the backing plate. Pull the rubber boot (blue circle) back and slip that part of the cable into the boss (arrow).
Yes thanks I have the pieces. On the photo one can see that the rubber boot is pushed back from the metal head. You can see that it is metal against metal. Thank you for your replies. I'm dumbfounded.
This is the best picture I can find in a quixck search, hopefully you'll be able to see what I was trying to describe.
