911hillclimber
These carbs are certainly 'edgy' to say the least.
Sad to think of putting the bikes away, but salt is on our roads already.
My mixture screws are cross drilled, the cross drilling is a large hole, about 1.5 mm dia.
one carb will stall the engine if the mix screw is down tight.
the same design of carb on the other side does not do the same!.....The K3 on CB, CL and SL carb bodies ALL LOOK the same, but internally are not.....Additionally, While the taper is the same on K3, K4, K5 mixture screws, they are not cross drilled like the K6, K7 mixture screws, and CL bodies have smaller air jetting than CB or SL versions......
Further, the mix screws seem to do nothing.
my tachometer says 1800 rpm that feels so close to stalling so maybe less, but still the screws do nothing....As a general rule, mixture screws ONLY have significant effect BELOW 1350, maybe as high as 1400 RPM....... Correct idle speed is ~1300.....
I have found that the relation between the engine speed screw on the slide is very sensitive to the mixture screw, and if out of kilter, one side will run hotter than the other, the hot side running smokey rich.
I can change the heat by re balancing the speed and mix screws, and turn a smokey hot side to the opposite side.
atm I have a heat balance, but I am not at all confident it will be the same next time I start it.....
Is there a replacement carb available other than the pairs you can buy for a £100 or so?
Some thoughts about 175 carbs, apologies for length.
I now have 5 pairs - two 653A CL175 carbs, two 306B CB175 carbs, and one pair of CB200 carbs.
Once removed from their respective manifolds it is very difficult to tell them apart, as the identifying code is stamped on
the mainfold, rather than on the carb body. I had always assumed that the actual carb bodies were all identical, and that by
swapping all the brassware around you could, for example, make a CL carb into a CB one, and vice versa. I am now not so certain.
My CB174 started life as a K4. I have since rebuilt it into a K6 frame and running gear. Before I laid hands on it, I don't
think it had been touched very much, which is an important point. Back in the day, these bikes ran perfectly when new, before
grubby little hands started pulling them apart. Fast forward 50 years, during which time who knows what parts will have been
swapped, floats adjusted, or just general wear, leading to the problems some of us experience !
After giving the CB175 carbs a good ultrasonic clean, and checking that the correct jets were present, needle in correct slot
and float levels correct, the bike ran as expected, while the K4 air filters were fitted. These are slightly smaller than the
later ones, with longer intake runners, no internal labyrinth in the air boxes, and larger air inlets. When I swapped these
for some CB200 filters, the bike refused to rev out, stumbling past 7k rpm. With the filters opened up by removing the
restrictions, performance was restored. Why this should be I have no idea, as I'm sure the actual K4 motor is the same as the
later ones. I suppose the carbs are matched to the air filters, although on paper the K6 carb spec is the same.
I got the CL175 before I got the CB175, and immediately tried to turn the CL into a CB175, changing the exhausts and carb jetting
to suit, as I thought. It would probably have been fine if I'd just cleaned the carbs and ran it as a CL. Instead, I fitted
aftermarket rebuild kits, gaskets and brassware, then wondered why it didn't run well. Along the way, I lost track of which
parts were original, and which carb they came from.
My CL now has ( I'm fairly certain ! ) CB175 306B carbs fitted, with the genuine Keihin 98 mains, 38 pilots, needle clip in
centre slot, running David Silvers pattern CB exhaust systems. Even so, it caught me out with its sensitivity to air filters.
Following the CB175 experience, I assumed that less restrictive filter was the way to go. In fact, it ran badly on these,
problem resolved by fitting unmodified (apart from foam) CB200 filters, which are same as K6/K7 filters, apart from a slightly
longer ( I think ) intake runner, to compensate for slightly shorter CB200 inlet manifolds.
Speaking of which, I haven't noticed any performance difference between the 175 and 200 manifolds. 200 manifolds have tappings
for vaccum gauges, which might be useful.
I can't see ( or with my limited abilities, measure ) any difference between 175 and 200 carb bodies. The CB200 only has 88 main
jets, mounted on different jet holders to the 175 items. CB200 jet holders have a few extra holes in the (?) emulsion tubes.
All else the same as the 175 carbs.
The CB175 and CB200 carbs have solid mixture screws, both my CL175 ones had a curious cross drilling near the tip. If the solid
screws are turned fully home with the engine ticking over, it stalls. The holed tips can be screwed in and the engine keeps
running, at least on my engine.
So overall a success? Seems so.
I have a proper ultrasonic cleaner, and in my view they are over rated. Don't put dirty old parts in expecting them to come out looking brand new. Yes, they do get dirt off / out, but they don't work miracles.
Most interesting...
Started the CB yesterday after a few days 'rest' to see what happens, long adjuster in hand, so full of confidence!
Tricky to start and run well on full choke, and takes a long time to warm up so it will tick over on its own, maybe 3 mins?
After 5 it ticks over at 1500 and I've left it there, throttle response is really good, exhausts even temperature. Hot start instant on elec start (haven't tried the kick start ever).
This will seem trivial, but actually popped it into 1st gear and RODE the thing up and down the cul de sac outside the house (for the USA, a cul de sac is the end of a dead end road in the UK), it is SO SMOOTH in first, goes well and the new brake linings need bedding in...Felt really nice, no helmet or anything so well worth it while the wife was out shopping.
Surprised how expensive classic bike insurance is in the UK, lowest quote is £63, worst is £108 ($80 to 120$ ish).
Very satisfying when after being passed by morons in BMWs to pass them in turn as they fume sat in traffic. What is it with drivers of German cars ? ( Porsche excepted ).
