ericfreeman
A customer recently brought me his 1972 CB450 that was previously at a different shop where they told him one cylinder was dead and there was nothing they could do. He brought the bike to me to see if I could help. Over the past few weeks I reset the valves (all were tight), removed and checked the cam chain tensioner while the valves were all slack, set the points and dynamic timing, replaced faulty spark plug caps and fitted new B8ES plugs. I also cleaned the carbs, which were in pretty good shape. I found a massive vacuum leak on the right carb at the manifold/head joint so pulled both manifolds and replaced the gaskets.
After balancing the carbs using an infrared gun on the header pipes, I went for a road test. Bike ran great until about 4-5,000 RPM when it would start stuttering. Right plug looked good while left was black and sooty. Re-checked everything electrical (about 5 times) and couldn’t find any faults. Pulled the left carb (about 6 times) and finally noticed the Air Idle Jet, that little brass tube pressed into the intake bell at the 6 O’clock position. I didn’t realize it was a jet and yes, it was blocked. Soaked the carb overnight and used a .45mm welding tip cleaner to clear the small passage. Also checked the right carb and it was OK.
Bike now runs fantastic and revs smoothly throughout the range. A great riding bike and I’m envious of the owner.
Moral of the story is to check EVERYTHING and never assume you haven’t missed something. I’ve done lots of carbs but this was a first for me. Glad I found it and I was ready to pull out what little hair I have left!
