bladen
Plugs at idle, Right:Battery at idle is 12.9V, at 5k rpm around 14.2V. Charging system works.
However, the bike does have a flat spot in its power band at 7.8-8.5k rpm, it feels like it begins to miss or just leans out. It pulls strong until then, and smooth. I did a plug chop, 8k rpm for 2 seconds in first gear then killed it, here are the plugs
Left:
Right:
Carbs are 26mm float, 35, 70, 115. no air leaks after several sprays with carb cleaner all over. Several rebuilds, as many OEM parts as I could source. Any ideas as to what’s going on? Like I said I have the original airbox housing coming in, maybe that’ll enrich the main circuit a little.
Left:
