My CB350K4 and its problems
Battery at idle is 12.9V, at 5k rpm around 14.2V. Charging system works.
However, the bike does have a flat spot in its power band at 7.8-8.5k rpm, it feels like it begins to miss or just leans out. It pulls strong until then, and smooth. I did a plug chop, 8k rpm for 2 seconds in first gear then killed it, here are the plugs
Left:
Right:
Carbs are 26mm float, 35, 70, 115. no air leaks after several sprays with carb cleaner all over. Several rebuilds, as many OEM parts as I could source. Any ideas as to what’s going on? Like I said I have the original airbox housing coming in, maybe that’ll enrich the main circuit a little.
Plugs at idle, Right:
Left:
I'm glad the charging system is in good shape.
Do you experience the same flat spot in all gears? I feel like chops are usually done in a higher gear, but I've never done them aside from a little two-stroke moped I had at one point.
Were those fresh plugs before you did the plug chop? If the main jet is too rich the motor will kind of bog down at WOT, falling flat on its face. I guess the idea is to keep increasing the main until this happens and then drop back down a couple of sizes. That's how I approached it with that moped.
Your plugs seem to show more heat, as in a lean condition, which I guess you already suspect based on earlier posts. For 8000 RPM and possibly having not been fresh, though, they don't look bad to me.
Sorry if this has already been discussed, but have you verified the spark advance angle using a dynamic test light? The high rpm timing depends on the proper function of that mechanism.
Same flat spot in all gears, yes. It’s very noticeable and feels kind of like one cylinder falls off. I verified advance yesterday while doing timing, but I was not as thorough as I could’ve been due to the noise, I’ll do a better test soon. It appeared to work fine.
The plugs are old, about 2500 miles on them, they’ve been through a lot.
I feel the plugs being lighter after running at high rpm shows that it is not bogging due to richness but to a lean condition, or lack of spark.
I suspect either I need a larger jet in the main, which I will try next, or that my condenser and coils need to be updated. For now, this is out of my price range and it will need to wait a couple weeks.
Keep in mind that at high RPM there is way more heat and that's what ultimately cleans the plug. So it's perfectly normal to see a difference like that between idle and 8000 RPM. I do agree that it's not rich at high RPM, so a larger main might help.
A dynamic test light should show that the spark is occurring at an angle between the two full advance lines. Advance timing is intended to optimize power, so if it were off substantially it could explain a flat spot.
Coils won't hurt since you have originals, but sounds like you're fine up to 8000 RPM until you can get new ones. That's plenty of bandwidth for street riding.
Yep! I’ll try the larger mains, and update. If the coils are the cause, I’d have them fixed not because I want to reach 8k often, but because I feel this bike needs to run perfect, for my own satisfaction haha. Thank you for your help.
