Yes, I meant to comment on the creativity.I approve of those heat shields for sure.
Do you mean that it still runs but won't take full throttle long?Unfortunately still nothing.
No it will not start now, hasn’t started since November.Do you mean that it still runs but won't take full throttle long?
Yeah, do it all and do it right. I like to adjust valves then cam chain, to get that out of the way before points and timing.
I'm guessing it's a fuel thing. Starving at high speed. Unplug fuel line from carb and turn on petcock. Is it a healthy steam? A plugged gas cap vent will flow strong then get less as the vacuum builds.
Maybe that’s my situation as well, I haven’t gotten it to start up, I see fuel is in the line and when I adjust the Petcock fuel flows out. The fuel I have in it may be stale as another mentioned. I know my carb is fine I cleaned and replaced most of it.+1 on going through the tune-up.
Afterwards, it would be a good idea to verify that the charging system is working properly. Poor or no charging could explain both the high rpm issue and the weak battery.
My first vintage bike (74 CB450) was sold to me with a non-functional charging system — it was running purely on the battery when I test drove it.
I believe my issue is electrical, had a gas leak those few months ago so decided to do a full service.
Started w/ the throttle and cable as the cable was cracked and no longer responsive. fuel line, then Oil change, cleaned carb, peacock, clean tank, new gaskets, etc. Noticed my battery was weak when I’d press the horn, so replaced that, the battery.
Other issue I noticed The bike would reach top speed/full throttle then bog down. Didn’t know how to approach it so I ignored it by not going full throttle.
I’m assuming now that these issues are correlated and was inevitable. A timing / points issue possibly.
So I adjusted points today after reading some of y’all’s posts. Unfortunately still nothing. I also replaced the spark plug, and I’m out of ideas. I really don’t want to pay for someone else to fix my bike.
Yes it has spark, I’m looking for a Manuel on how to cam chain adjust and valvesDid you check for spark? Even if you have spark, if the points are worn and the gap is closed down from spec, the timing would be retarded and it would be hard to start.
I’ve heard it go back and forth w/ starter fluid. How would you suggest I go about it?My experience is limited, but here would be my suggestions.
You could check for spark with plug pulled and sitting or strapped to engine to ground. Can you see spark?
You could try and verify points at open time(fire time) matches when they should fire compared to valves/piston/crank position.
What year and make is this? OK, other posts indicate 1971 Honda CL100.
Pull the plugs after a few attempts and smell and look for gas. Is it getting gas? Or flooding. If plugs are wet with gas try and air it out before retry.
Gas good? I hear gas can get stale.
I'm not sure if this is useful on these bikes, but a can of starter fluid can be a useful trick. Seems most helpful on my fussy old lawn mower.
Typical use is to give a spray toward carb intake and then try to start. Sometimes it's enough to get it running, or just a brief moment of running if normal gas is not being delivered. You can use it to detect intake leaks spraying around intake looking for a rise in RPM.I’ve heard it go back and forth w/ starter fluid. How would you suggest I go about it?
Now, Its like it won’t grab a gear and accelerate past 10mph regardless of gear I’m in. I’ve tuned the carb mixture of fuel and air so that the idle is smooth but as soon as I pull on the throttle it bogs down.
