timothy.firth
Long story short I was on a ride up north in Mount Vernon and allowed rattle/ticking away started happening and then I stared dropping my right cylinder.
I made it back to Mount Vernon and did a valve adjustment in a motel parking lot, but noticed that while the intake side could be adjusted normally the exhaust valves had a tremendous amount of clearance. So much so that I could rotate the adjuster 360 degrees. Just for fun I rotated the engine 360° to the non-compression stroke and the clearances were now correct.
Now I had to get home so I carefully made my way back to the shop - on the way the valve noise remained and the cylinder would occasionally drop for a while then come roaring back. I thought for a second that the cylinder issue might be a fuel flow problem so I stopped by the hardware store on the way back and got rid of my in-line fuel filters to improve flow. That seemed to help tremendously for a few miles, but then it started again.
Back at the shop I've started taking things apart and the exhaust valves cant be adjusted BUT I was exercising the follower on the right cylinder and all of a sudden I could adjust the clearness and get it in spec, which makes me thing the valves are sticking for some reason?
Compression cold: L=165 R=155
Just wondering if anyone has experiences anything like this and could offer some guidance.
