Hondamatic CB400A/CM400A/CM450A 'Community' Ignition Test Kit!
Maraakate
Lancaster, PA, USA
Hello to all VHT Members,
I've setup a community test kit for diagnosing ignition/no-spark/bad performance conditions. Swapping your parts with the ones out of the kit can help you diagnose if you need a stator, CDI, or coil.
The kit includes:
  • Prototype CDI
  • Known-good Ignition Coil with new NGK Caps
  • Kill switch assembly
  • Prototype Change Relay
  • D8EA Spark Plugs
  • Stator and Rotor Assembly
Shipping is approximately $80-90 USD at your expense via UPS Ground. This includes a return shipping label. Due to the nature of the parts I don't want them walking off so I am asking for a "core" charge of $150. The core charge will be refunded to you once I receive the package back. I intend to get a a Peak Voltage Adapter and a flywheel puller to complete this kit. We've successfully used this kit already on VHT to diagnose a bad stator.
Send me a PM if you think you need to borrow this kit. Thanks and looking to help VHT members get their Hondamatics sparking again! (y)
Got a working stator/rotor assembly. Had to increase the "core" charge appropriately as the part is quite rare.
