NewRidersOldHonda
Hello everyone. Shout out to BallBearian for the free CT200 engine and Carb. Greatly appreaciated!
This engine will likely serve as a great parts resource for me.
I started off removing the rocker assembly, head, and cylinder
Next step was to remove the clutch
With the clutch cover, side case, and spring mechanism out of the way, the clutch can now be removed using a special tool and socket aqcuired from DrATV...once the selector unit, and oil filter/filter cover are removed.
Selector arm removed, you can see here one screw has been previously damaged. That will be taken care of later. For now lets remove the filter cover
With the filter cover removed, here is the nut to remove the clutch, along with visible socket required and holding tool both visible. You must bend one of the tabs out of the way before the socket will be allowed onto the nut. This washer/tab combo prevents the nut from backing off.
With the clutch removed, the gear oiler, primary drive gear, gear selector/ drum stopper, and camshaft can now be removed and our focus will attend to the opposite side of the engine
Selector splines on both ends look great. Will be useful.
Questionable camshaft lobes...now onto the other side to remove what is left of the points plate.
With the points plate removed and the stator cover off, the stator and magnet are now accessible. Time to remove those, as well as the final chain drive gear.
Now time to seperate the case halves, and remove the remaining internal assemblies. I will do this in a follow uo reply, as I have reached the maximum allowance for pictures in one post.
