Granticus
Hello,
I'm a new member, new motorcycle owner, and new rider. So new in every sense.
I recently purchased a 1978 Honda CB400A Hawk Hondamatic. It has 11,000 miles on it and overall seems well cared for. It has a Lithium Ion battery in it and a newer LED headlight installed. All the other electrical components seem original.
It ran well for the first few months on short trips around town. When I started going on longer rides I started having some problems.
It would run well on my way to a destination about an hour away. Then, it would be parked for a few hours. Finally, as I was riding it back home it would lose power while riding. I would be going 60mph and suddenly it would slow down and the bike couldn't accelerate over like 30mph for a bit before eventually stalling. I pulled over on the side of the road and tried to start it again without luck. After waiting 5-10 minutes, all the sudden it would start right up and ride like normal. I had this same experience on 3 or 4 different trips.
Then the last time I rode it, after stalling again I let it sit for awhile, but it just wouldn't start again. I eventually drained the battery trying to get it going. I had to get a friend with a trailer to take me home.
A different issue I noticed, that may or may not be related, is my speedometer light or the brights indicator light would not get power. I finally traced it back to the fuse box and saw: top 15 amp fuse looked good, the middle 7 amp fuse was blown, the bottom 7 amp fuse slot had a 10 amp fuse in it. I replaced the blown 7 amp fuse with a 7.5 amp fuse I had on hand. I then was able to get the speedometer light and the brights indicator light to glow but just very faintly like it wasn't getting enough power.
What I'm considering right now:
- Replacing the middle and bottom fuses with the correct 7 amp ones
- Trying to add up the overall wattage use to see if I'm unable to provide adequate power for everything
- Replace the remaining standard halogen light bulb with LED ones (should be less watts and brighter)
- Seeing if I need a new Regulator/Rectifier meant for use with Lithium Ion batteries
- Replacing my ignition coil (possibly with the GM mod mentioned elsewhere
- Replacing my CDI since the symptoms seemed to line up with a failing CDI
I have a multimeter and I'm trying to figure this all out. I would love to know if you think the symptoms I mentioned are pointing to a specific problem? Are the two problems I've mentioned at all related? Do you think any of my next step ideas are worth doing or not necessary?
Thanks in advance! Please let me know if I can provide any additional details.
