javaman
I recently began restoring a 1973 CB450K6. I disassembled the engine in the fall of 1978 after having heard some alarming engine knocks. I shut it down and started to take the engine apart. I am trying to finish what I started. I've been through the crankcase, the transmission, and the crankshaft and discovered no obvious problems. Today I started disassembling the cylinder head, where I discovered that the rear cam chain guide had failed. The bracket is broken and one edge of the wheel appears to have broken off from the whole. The front guide appears to be intact. The cam chain tensioner shows no obvious problems although the plastic wheel shows moderate wear. I'd appreciate your thoughts on likely cause, places to look for or rule out related damage, and any other recommendations for how to proceed.
