AmericanIron
At risk of over-using the resources of this forum, going to ask another question. A little context as to why solving this is a high priority: I'm a new motorcycle rider, since buying my CB175 in October. After taking a basic riding course and getting my learner's endorsement, I'm now just starting to ride in traffic and going over 20 mph. Very much a beginner. After doing all the standard basic maintenance and tune-up, the bike idles and rides pretty well from a cold start and after riding up to about 15 minutes. However, when it gets on to about 20 minutes or more, the engine frequently dies while at idle.
This has been happening since I first started riding, through all the maintenance items, through two sets of carbs and two sets of mufflers (the new, quieter mufflers actually make this more of a problem because I won't notice the engine has died until I do something like attempt to roll in power while turning a corner). The engine always restarts easily and continues to make good power. As you can imagine, as a new rider this is hugely distracting. I need to solve it before going out in traffic again. Here's everything I can think of that might be relevant:
- I am temporarily running off a pair of $30 Amazon carbs until I do a proper rebuild of the original Keihins. This problem was the same when I was running off the Keihins.
- I keep the idle at about 1,400 rpm. For my last ride I increased the idle significantly in an attempt to prevent the stalling, but it happened all the same. Now wondering if increasing the idle speed is not the right short-term approach to stalling.
- Ignition has been gone through and spark is strong at idle
- Carbs have been synched and adjusted to the best of my ability. Right hand carb has become non-responsive to air bleed adjustment (it continues to run with the air bleed screw completely removed, though stalls with the screw bottomed out.) I find it surprising that the the previous Keihin carb, also on the right side, exhibited similar behavior of the air bleed screw. Coincidence? Is that carb slide lifted to the point that it's off the idle circuit?
- Fuel tank is sediment free and fuel valve screen is clean
- Compression is 150 psi both sides
- Throttle cables are in good shape and carb slides rest on the adjustment screws at idle, with approx 1/8" slack at the carb end.
I am out of ideas as to why a warm engine runs fine after 15 minutes but not 25 minutes. Anybody got one? Be grateful for advice on this.
