SomersetChris
My barn find USA import 1972 CB450K6 has an electrical problem, despite only showing 8000 miles & not being used for a very long time.
The original wiring looks good & I am going through it as methodically as I can - checking connectors & earth points.
I have a good AGM battery, checked the battery to engine & frame earths, ignition & handlebar kill switch both work - but there is a small voltage difference between the black harness wires & earth with the ignition off?
I have removed the coil mount, coils & condenser, cleaned the earth points, checked the points wiring, cleaned the contacts & checked the gaps & reassembled.
There is also a voltage drop between battery +ve & black with the ignition on, no spark at the points & no lights!
I can't start the engine, so all tests are static.
The rectifier is not the selenium type & passes all the usual tests - all work one-way only, 1.1, 0.55 & 0.56
The alternator stator coils have resistances of 1.1, 0.9 & 0.3 ohms between pairs of wires. No earth leaks.
The regulator measures 1.13k ohms between green & black, infinite resistance between green & yellow, black & yellow.
Using the diode test between the green & black gives 0.73 & 0.72 in both directions - not sure if that means anything.
Before I replace anything, does anybody think that there is a problem with a particular component, from these readings?
I would like to get this bike running before I spend a load of money on it & would be very grateful for any useful advice.
Thanks to anyone who contributes!!
