Stanagui
Hello New comer to the forum.
Hello I have a 1970 Honda sl350 k1 with some electrical issue got a new battery when I turn on the bike and at idle it will run quite low anywhere between 11.7 if the bike took some kick to start to 12.7 if the battery has freshly charge and fire up on the first try.
Today I took me a few kick to turn on mostly my fault as the tank was empty
Getting the battery down to about 11.4 before firing and 11.7 once’s it was idling at 4-5k rpm the battery 12.14
When down to the pink and white and yellow cable showed 12at idle and 36 and 5k
Then swap to pink and yellow showed 16 at idle and 30 at 5k
I imagine my issue is with the voltage regulator or rectifier should I change both and what to use
my startor is currently connected to this plug connector and not directly to the connector and not the other one is this correctly connected
