Maraakate
Someone sent me a leaky float bowl to fix a leak. Here's how I do it.
Take a vacuum/pressure tool such as a Mityvac and put the line on the drain line. Cover the top.
Fill the bowl with alcohol or mineral spirits. With the Mityvac set to PRESSURE try to pump 5-10 PSI in it. Look at the bowl. If it doesn't hold pressure you'll see bubbles where the leak is.
Bubbles forming and pressure dropping.
Hair line crack, couldn't see it before, but now I got a hint where it is.
I used an adjustable temperature soldering iron, set it to 775F, with some flux and a pencil tip soldered it up. You almost kind of have to "sweat solder" as you'll see the pool move around. Try to get it as best as you can, then verify it's not leaking any more with the Mityvac. When I'm satisfied I clean it up with a small points file. A small blob at the bottom is fine, won't hurt it. If the hairline is completely top to bottom then you'll have to try and clean it up better. The file won't reach that low for me at the joint and because it doesn't affect anything I don't worry about it. Since this picture was taken I spent a bit more time on filing.
Holding pressure.
Clean up any slag left in the bowl and you're good to go. An alternative way of doing the soldering is to use a butane pen torch and sweat solder like you would a copper pipe.
Holding pressure.
