jcharlet
I've just gotten a compression tester and tested compression on both cylinders on my '80 CM400T. Bike hasn't run in 18 or so years. I have not yet adjusted the valves, either.
Readings are cold.
Lt cylinder 158 psi
Rt cylinder 149 psi
Am I looking ok here? I know these are below spec (185 +-14 acc to the FSM) but again, this is cold and valves aren't yet adjusted. Oil is fresh.
Thanks!
Josh
Readings are cold.
Lt cylinder 158 psi
Rt cylinder 149 psi
Thanks!
Josh
