Hi guys, wondering if anyone can help my diagnose my leaking overflow on my right side carburetor. Some details below...
Any ideas on this one? Thanks for your help!
SOLVED: Thanks for your help guys! It ended up being that I needed to thoroughly clean the sealing surface of the float needle valve - not the valve itself, but the carb body. Per a recommendations below, I cut a cotton swab in half, put it in my drill, and used carb cleaner and the swab to clean the sealing surface.
Only right side carburetor is leaking, substantial leak upon start up (rebuilding bike and have not gotten to properly idle yet)
When I removed it, bowl was full of gas - making me think it's the float/plunger that is malfunctioning and not the overflow pipe
I switched the plunger and float between the two carbs - and the issue stayed with the right side carb. Now making me think it's a problem with the sealing surface and the plunger.
I checked the hole that the plunger seats in and everything looked fine
