Sam Ruger
OK. Stupid question. I have a 450CL and have read, and a mechanic confirmed, that I am to perform "starter clutch maintenance". What does that mean?
That's an odd recommendation from a mechanic. There really is no maintenance on the starter clutch, it works or it doesn't and to do any "maintenance" at all is basically the same as repairing it - you can't get to the internal parts to maintain them without fully disassembling the starter clutch in the same way required to do any repairs if it wasn't working.OK. Stupid question. I have a 450CL and have read, and a mechanic confirmed, that I am to perform "starter clutch maintenance". What does that mean?
My experience is that the Honda starter clutches are rebuildable, as I have done everything from Goldwing bikes to the CB DOHC ones in the past. I would call them a over running roller clutch in design. The pins and springs and rollers are normally still available from Honda. The body of the clutch usually is NLA, so if worn the only option is to have it hard metal coated and machined by a machine shop. Then the new parts noted above can be installed in the refurbished starter clutch body.The starter clutch on my Piaggio scooters (same engine as Vespa) is what's called a sprag clutch. It's very different than the clutch we're familiar with on the twins and bikes of that era, but like the Honda clutches it's really not serviceable. It can be packed up with crap from dirty oil and I had to soak one in kerosene for days to get it clean enough to work right again. Maybe the mechanic was more familiar with that technology.
I don't mean to differ with him or insult his knowledge in any way, but not even Honda (known for a high level of maintenance recommendations, take a long look at any FSM and you'll see maintenance and repairs of things most just replace) mentions any maintenance of the starter clutch. To actually do any maintenance, the mechanism would have to be removed and disassembled in order to actually see if the parts are in working order since there is no way to inspect the components involved without doing so. The only actual maintenance I can think of would be checking the tightness of the 3 screws holding the assembly to the alternator rotor, because if they come loose the reliability of the starter clutch is immediately reduced and extensive damage can result if it continues to be used. The unit runs in engine oil and the only wear that typically occurs results from hard starting or inaccurate engine tune causing excessive load on the starter clutch. Otherwise, it simply works until it begins to slip occasionally due to long term wear or the results of damage to the clutch due to other engine problems.Thanks to all. The mechanic I talked to actually restores classic bikes for a living. When I'd never heard of it, he assured repeatedly of the need for maintenance and went into a five minute speel, losing me in 30 seconds. I'll watch for additional replies.
