CL450 Carb Sync
GMX
Arizona
Today, with the carbs mounted and filters off, I noticed that there is a noticeable difference in in the left and right carb intake openings...ie how the butterflies are positioned.
Just ran across this video and was wondering what you guys think of it...hadn't seen it before...is it worthwhile trying it?
Honda CL450 Carb Bench synchronization​
Oops, I was looking at the choke plates (obviously) (visible with the air filters off), not the butterflies...doh. Then when I saw this video my brain didn't register he was not adjusting the choke plates but the butterflies....
But my choke plates do not appear even in the bores, so can they/should they be adjusted?
I will have to take the carbs off to get a good look at the butterflies...to see if they are even in the bores...and maybe adjust those.
The spring-like strap that connects the choke plates should hold them in (nearly) the same position. Investigate that.
Bench sync is a starting point, if you had the carbs off; you still have to set the sync with the engine running. Carbs mounted, you can lift the CV cylinders through the intakes, using a non-marring tool, like a Popsicle stick and shine a light into them, if you don't want to dismount them. It is hard to see the gap in the plates when the throttles are at idle.
The idle setting screws should allow the throttle plates to close when the screws stop touching the stop, then you can turn them in so they just touch the stops, then turn them the same amount, which will get them close to the same. This assumes plenty of slack in the throttle cables. With the engine running, set the idle rpm by adjusting those screws the same amount, and feel the exhaust pulses from each cylinder. When they feel the same, you have as good an idle sync as they got when your bike was made. Reduce the slack in the throttle cables, then do the same feel test with the throttle grip held open to about 3k rpm, and adjust the cable at one carb. If you want a better sync, vacuum adapters or a Uni-Syn is required.
If you had the tank off, make sure the throttle cables are in the cable splitter fully, so one carb isn't pulled more than the other, or you won't get the throttle sync right.
Thanks for that info WintrSol...I will see what I can with the carbs on the bike, using a bamboo chopstick to raise the CV pistons. If not, I will take them back off, again...
Tank is off.
Throttle cable adjuster at the twist grip is fully slacked. (ie screwed all the way in with no threads showing)
My bike has a new throttle cable...Is there a method to be sure both throttle cables are in the splitter fully?
Reminds Me of something an old boss told Me once, "You can make work, out of most anything, if you really put your mind to it."
I've seen enough questionable stuff from that guy, I'm not watching whatever method he uses.
