Packard3155*
first step removed gas tank. As usual full of crap. Petcock trashed. Broke hold down rubber. Removed points plate. see photo of left side points. When removing points plate, yellow wire fell out of the bullet connector. See also felt pad touching points connection. Removed timing advance unit and re lubed plate. 2 years ago removed left plug and put dexron trans fluid in cylinder could not break right plug loose. a month ago I sprayed pb blaster around plug and let sit for 3-4 weeks. Then this week sprayed freeze-off off on the plug and it came out real easy. Also see left plug wire broke off and 90 degree connector full of hard stuff.
