Grumpybugger
In this case 3 motors. Darn lucky he had that spare K7 motor when I picked up the bikes.
I don't mean to butt in here, I'm currently working on a 1968 CL175 K0 as well, wondering if you might have in your spares box, the left and right rear signal light mounts and a gearshift lever that you might be willing to sell. Also do you know if anyone reproduces the speedo rubber gasket.Hot air.
I'm working on my sloper as well and have several totes of spares. Let me know if I can help with anything.
What is the status of the other motor? Any chance you can compare them to confirm things are as they should be?
Wow! Good catch. Thank you!!
I don't want to seem critical, or open a can of worms here, but it looks like you waited to put the clutch rod seal in until after the lower case was on. It appears the crankcase edge carved off some of the plastic around the outer part of the seal, and personally I wouldn't trust it like that.Not happy with how the new clutch rod seal went in…….I’ll add another one in with my next parts order![]()
During a bottom end overhaul, it's best to put all seals in place prior to mating the crankcase halves so Hondabond can be put around them without the disturbance of pressing them into place afterward.
