Checking the idle on a CB400A/CM400A/CM450A Hondamatic
Maraakate
Lancaster, PA, USA
I made a small video showing how a properly tuned Hondamatic should respond.
When you do this check you really ought to use a portable tach. However, it can be done ear.
If you can't achieve a good idle there are a number of things it could be such as:
  • Dirty idle jets
  • Shrunken or missing passage plugs
  • Pilot mixture screws with broken/bent tips, missing the o-rings or washers, or o-rings needs replaced
  • Air leak from insulators, air box rubbers, their clamps or insulator o-rings. Inspect insulators carefully for cracks.
  • Faulty ignition system
  • Valve clearances way too tight or way too loose
  • Poor compression
  • Leaky valves
@LongDistanceRider has a thread on rebuilding the carburetors here. I have a thread on diagnosing the ignition system here.
EDIT: By request and some slight confusion, I have added a second video that shows the use of a portable inductive tach. In my opinion, a tool everyone here should have if they are serious about maintaining their vintage bikes.
